what should i use when i race D or (D)
Old 08-29-2010, 10:23 PM
2000 maroZ's Avatar
Exclamation what should i use when i race D or (D)
hey guys when I race someone of the line should i put it in 1 2 D D or just D with the circle around it? Thats over drive right?
Will putting it in 1 2 n D just driving around will that hurt the trans?
2000 maroZ is offline
Old 08-30-2010, 07:38 AM
Moderator
AL SS590 M6's Avatar
Standing start race use drive.
AL SS590 M6 is offline
Old 08-30-2010, 07:56 AM
razor02097's Avatar
Let the trans decide the gear when you race, it is programmed not to damage itself.
Most times the D without overdrive is for when you are towing (yes the F body can tow believe it or not) on the freeway the trans doesn't "hunt" going in and out of overdrive causing the trans to heat up.
If you are racing then you are accelerating at WFO. It isn't going to make you go slower if you use (D).
razor02097 is offline
Old 09-16-2010, 01:02 PM
OutsiderIROC-Z's Avatar
I dragraced my 95 Z28 in Drive.
OutsiderIROC-Z is offline
RUENUF
03-13-2016 03:37 PM
Daluchman1974
09-11-2015 06:12 AM
94ZinEdgewater
09-08-2015 09:55 PM
Slayer
08-17-2015 03:55 PM
karpetcm
08-14-2015 03:02 PM
Quick Reply: what should i use when i race D or (D)
