What should I run?
What should I run?
Im planning on 383 stroker, Le2 heads and Custom nitrous cam..
Car will be around 3100-3200 pounds,TH350 Tranny,4500 stall,373 gear stock 10 bolt... and spraying at least a 200 shot..... Can anyone tell me what I should run in the 1/8 mile and 1/4 mile... and mph?
94 Z28
94 Z28
Re: What should I run?
94 Z28
94 Z28
If you get the car to hook it should run at least mid 10's @ 130
If it doesn't break and you hook up you should be in the sixes easily in the 1/8, however if it hooks you may be picking your rear off the ground. hopefully you have a driveshaft loop, at least a six point bar, a fire bottle, open lugnuts, a tranny shield/blanket, and maybe some wheelie bars...
