new best times! bolt on LT1
Just wanted to share my new times. Previous best was 8.76 at 81.84 with 2.12 60ft. I added a 3000 stall and removed the front swaybar, everything else the same. Weather was finally pretty decent, and I was expecting high 8.5s since Im still running Sumitomo HTRs. I feathered the throttle and launched like a bat out of hell. I got the slip and I nailed a 1.93 60ft with a 8.49 at 81.38. I busted the second run spinning and the trans shifted when I let out of it (still got a 1.98 60 though). The track was busy, so I had to wait over an hour for my third run. I gave the tires a good burnout (which I swear works on these tires) and here's my new best:
1.91 60ft
8.43
81.98
I was representing as the ONLY LT1 at the track. I ran a 2004 ZO6 Vette and he beat me by .02. We were both shocked
What do you guys think, and where should I go from here?
1.91 60ft
8.43
81.98
Re: new best times! bolt on LT1
Nice improvement. .33 in the 1/8th should be at least .5 in the 1/4. What gear ratio are you running, and what converter did you go with?
I'm getting ready to order a converter for my near stock LT1. If it nets me .5, I will be way happy.
them are some really good times. i have CAI, EWP, pulley, over you and ran these times yesterday
1.81 60ft
8.411 1/8th ET
81.84 1/8th mph
which in the qtr was 13.21@102.2
1.81 60ft
8.411 1/8th ET
81.84 1/8th mph
Im stil running 3.23s. A 3000-3200 stall really wakes these cars up. Ive seen many LT1 and LS1s run pretty good with 3.23s still, but the stall really makes the difference. Dont get me wrong, you should pick up some with gears (how much is debatable on the LT1) but the stall is better for bang for the $$
BTW, the stall is an Xtreme Transmissions converter. I got a hell of a deal and its a 9.5, bought it new off of someone who changed their setup
I have only 56k miles on my car, so I can really say for long-term. I have bumped up the line pressure though, through tuning. I also get the same mpg as before. I take it pretty easy though.
Originally Posted by MTBeni
2.12 was the average. Best ever was 2.02ish
I think the sway bar removal helped alot in getting those 60s on street tires. Im sure I could have gotten a high 1.8 with some practice. I have a total of 4 runs at the track with this setup, and the converter makes launching way different. The stall really helps it get out of the hole, but the swaybar helped traction
WSO(weapons system officer). The pilot just drives the plane, I do all the fun stuff. He goes where I tell him too
Plus, I get controls too and can fly.
yea I guess you can say that. Im also the one who "drives" in the weapon. Im sure youve seen some of it on TV highlights of a bomb going down a ventilation shaft or through a window.
