what controls the car to shift?
Your '94 has the 4L60E (unless you've changed it). If NOTHING else has changed and the only thing done was the transmission rebuild, then it probably wasn't rebuilt right. Or, you might even have a cracked transmission case, which a general rebuild wouldn't catch even if it was a good rebuild. Also, if it had to be rebuilt because you burned up some clutch packs and the converter wasn't replaced or cleaned out during the rebuild, pieces of clutch material could have been pumped through a fresh rebuild.
Just some thoughts....
07-04-2005 05:00 PM
