what controls the car to shift?
Old Mar 19, 2004 | 04:06 PM
SLeeper94Z's Avatar
after i got my tranny rebuilt my car is stuck in 3rd gear... I can manually shift the cars and its fine,what controls the shifting?
i know all the clutches are good and help?
Old Mar 19, 2004 | 04:38 PM
WS Sick's Avatar
Ifits a 4L60E its the computer, if its a 700 or 400 or 350 its a combo of the valvebody, and governor.
Old Mar 19, 2004 | 04:39 PM
WS Sick's Avatar
Modify that, there are solonoids in the valvebody of the "E" that help in that as well. But its all rpm or mph based.
Old Mar 20, 2004 | 07:12 AM
Raptor1's Avatar
Your '94 has the 4L60E (unless you've changed it). If NOTHING else has changed and the only thing done was the transmission rebuild, then it probably wasn't rebuilt right. Or, you might even have a cracked transmission case, which a general rebuild wouldn't catch even if it was a good rebuild. Also, if it had to be rebuilt because you burned up some clutch packs and the converter wasn't replaced or cleaned out during the rebuild, pieces of clutch material could have been pumped through a fresh rebuild.
Just some thoughts....
Old Mar 20, 2004 | 04:10 PM
Stephen 87 IROC's Avatar
If it's an E then check the wiring harness to the tranny. Maybe a pin got pushed in or bent at the plug.
97SSdude
Dec 31, 2014 07:43 PM
tds1213
Nov 27, 2014 12:55 PM
USAirman93
Nov 24, 2014 03:37 PM
Jul 4, 2005 05:00 PM
SLIMJIM
Jan 7, 2003 11:06 AM
