what clutch you guys use?
Old 07-24-2002, 03:53 PM
twistedwedge's Avatar
Post what clutch you guys use?
All 6-speed users....
What clutch you using and which have you had the best luck out of?
Looking for a good clutch that will hold up to slicks and street use.
1987 GTA- TH400 w/brake, 355, carbed, 11.3:1, TFS twisted wedge heads (non ported), Big Shot NOS, Lunati hyd roller .510/.525 lift 232/242 duration @.050, true dual 3" exhaust, hooker super comp 1 & 3/4" headers, flowmaster 2 chamber mufflers, no tailpipes, 6-pt roll bar strange 12-bolt w/ spool and 33 spline axles, BMR anti-roll bar, BMR LCA relocation brackets, BMR solid rod end panhard bar, PA tubular k-member and a-arms, PA coil over conversion, PA manual rack conversion, Weld Pro-Stars 15X10 w/28X12.5 ET Street out back, 15X3.5 out front
Best ET last year N/A,Stock suspension, on street tires, T56, stock rear end and 4.56's @ 3515 lbs: 12.46@115.1 (1/4) 8.15@90.5 (1/8)
drive it like you stole it!!
twistedwedge is offline
Old 07-24-2002, 07:10 PM
sideways_Into_3rd's Avatar
Post
nothin but the best ... the street twin
Black '94 Z28, M6
Heads. Cam. Traction.
Speed Kills. Drive a Ford, Live Forever!
Pics of the beast
Hear it idle thru the muffler
British Columbia - Team F-Body
www.bctfb.com
sideways_Into_3rd is offline
Old 07-24-2002, 07:13 PM
GP Moderator
Joe Brodman's Avatar
Exclamation
Star Stage III Ceramic. Has not let me down; I'm very pleased with this clutch.
Past clutches:
- Stock. Stock + nitrous = major slipping
- LT4 PP, Clutchnet Kevlar/Organic disc. Held the power, slipped BADLY on launches.
- LT4 PP, Clutchnet Kevlar/Bronze disc. Slip....hell no. Very grabby and chattery, hard as hell to drive. Held until one day it decided to blow all the pucks apart in the waterbox.
IMO, the only two clutches to go w/ on a T-56 are either the Star Stage III's (or better) or the McLeod Street Twin.
94 Firebird Formula Ram-Air, M6, T-tops, N2O, 12-Bolt, Bolt-Ons; was running 11's internally stock.432.8 RWHP / 588.4 RWTQ
No new times or dyno numbers with new top end (CC306, 1.6RR's, ported heads, etc.)
Joe Brodman is offline
Old 07-24-2002, 10:26 PM
RichJ's Avatar
Post
I'd say that the satisfaction rate is the best with the Street Twin (what I have). Some people love the Specs, but then they blow up and they don't love them anymore Spec has also been known to release bad designs on the market (like their old 4-puck kevlar design) and while they have good customer service and will stand behind their product, I'd rather buy something proven, spend a little more and not worry about it. Changing a clutch is something I'd rather not do on an annual or even semi-annual basis...
Rich
RichJ is offline
Old 07-25-2002, 01:34 AM
Tweaked Zed's Avatar
Post
I'm using a Centerforce pressure plate with a SPEC stage 4 ceramic disc. Holds nice, but chatters a little sometimes. Livable.
1995 383 Z28, black, M6, ARE heads, CC306, Crane 1.6 Gold, K&N Cold Air, 58mm TB, 30# injectors, LT1 Edit, SLP headers, 4" Mufflex, Spec Stage 4 Ceramic, SLP sfc, BMR Xtreme Duty TA and adjustable LCA's, stb, phb, Moser 9"(3.89,soft-locker), Nitrous Works, some Mickey T's on a set of Weld Pro-Stars, Harwood Cowl Hood, 98-up SS Spoiler.
Tweaked Zed is offline
Old 07-25-2002, 05:42 AM
Moderator
rskrause's Avatar
Post
Don't waste your time and money on anything other than the Street Twin.
Rich Krause
'95 Z-28 383 with Vortech, nitrous, etc.
"1FASTZ28"
rskrause is offline
Old 07-25-2002, 08:59 AM
N20Dave's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by rskrause:
Rich Krause
</font>
Ditto.
94 Formula M6
Last year 10.98 @ 126
355 stock heads, P600
In the works:
383 worked heads, D1, th400
N20Dave is offline
Old 07-25-2002, 09:22 AM
OneFlyn95z28's Avatar
Cool
We have had the BEST customer satifaction out of the Street twin. They only seem to be getting beter! Installed one last week with the adjustable master(A MUST for f-bodys 93-03) it was as smooth as a new stock Clutch
Good luck!
Ellis
Team Captain
Team North West F-Body
www.teamnwfbody.org
OneFlyn95z28 is offline
Old 07-25-2002, 01:06 PM
red
red's Avatar
Thumbs up
Using a SPEC stage IV ceramic. Much to my supprise it is street friendly after you learn how to slip it. I would recomend the SPEC if you don't have the money for the street twin.
95Z M6
383
and a few other mods
red is offline
Old 07-26-2002, 11:19 PM
Post
Thanks Guys... trying to help a buddy find the right clutch.
Old 07-27-2002, 08:38 AM
chevyguy3's Avatar
Post
Street Twin in my car, and 3 (soon to be 4) buddy's cars. i strongly recommend it
chevyguy3 is offline
Old 07-27-2002, 09:10 AM
zturbo's Avatar
Post
Twin disk here when i had a manual
Went through so many single disk designs it was not funny. Twin holds awesome just gotta worry about breaking other stuff then.
Steven
383 Inches of stroked turbocharged fun.
If one is good shouldnt 2 be great?????
TURBO=TORQUE
TORQUE=FUN
My Car
zturbo is offline
Old 07-27-2002, 01:54 PM
Ed95Pont's Avatar
Post
S.p.e.c ceramic.
6500 Rpm clutch dumps on slicks.No slip No chatter at all.
95 Formula Solid Roller 9 Inch 4.10 H.D. Locker,6 speed
Best 1/4 12.074 Best MPH 115.56 on STOCK HEADS
94 Hardtop Heads up Drag car
94 Formula A4 Stock
120,000 miles 13.82
Tow Rig 84 suburban 3/4 4wheel drive 388 small block
Ed95Pont is offline
BPS
9
03-05-2015 10:51 PM
Briah.hood
02-17-2015 02:10 PM
HectorM52
01-30-2015 11:08 PM
Red97LT1
08-07-2002 05:45 PM
Quick Reply: what clutch you guys use?
