very dissapointed
Old Jun 2, 2005 | 08:44 PM
badasschevy625's Avatar
very dissapointed
i ran last night with all the mods in my sig and went 13.7 does anyone have any ideas of what could be the issue here im very frustrated i went the same time as last year after all that work
Old Jun 2, 2005 | 09:24 PM
BoltOnZ's Avatar
Re: very dissapointed
is that including what you have listed as 'waiting for times with' ?
if so...what kinda tires are you on? 60'?
Old Jun 3, 2005 | 08:52 AM
TedH's Avatar
A 1996 automatic with cat back and cold air only? That time sounds about right. DA can easily account for a couple of tenths either way...
Old Jun 3, 2005 | 10:03 AM
CANTONRACER's Avatar
I might see a need to vent like if you ran...hmmm, 15 seconds...but a 1/10 or two off resorts to this? What were you expecting, 12's?
Old Jun 3, 2005 | 06:22 PM
Johnnynsac's Avatar
I say your in the area. People with headers don't even run that time sometimes.
Old Jun 5, 2005 | 02:55 PM
but i ran a 13.6 before 4.10 and nittos so what the hell
Old Jun 5, 2005 | 08:47 PM
LS1_03's Avatar
I would assume the DA was high, or you had some humidity.
What kinda 60's did you get both times? I see your sig has 2.12 as your best.
Old Jun 6, 2005 | 08:48 PM
i got a 2.0 this time
Old Jun 6, 2005 | 09:00 PM
MarkyMark's Avatar
Your not getting much good out of the gears and Nittos if you are still in the 2's range on your 60 foot. I could pull 2.0x's with 2.73 gears and bfg Drag radials. Now I switch to 3.73's and M/T Drag Radials I am consistantly 1.8x range.
My suggestion would be to lower the tire pressure on the Nittos and do a longer burnout and work on your launch a little. If you still can't get a good 60 foot, then I would invest in some M/T Drag Radials, cause they are da bomb!
Old Jun 6, 2005 | 11:49 PM
LS1_03's Avatar
2.0? You're getting a 2.0 60' and expecting gears and a tire to bust you down big time? Ain't gonna happen till you hit 1.8 or better man.
I hit 2.0s with my 2.73s on street tires. Of course, this was before the stall, but regardless I hit them consistantly. I'll just melt the tires now.
Either find the sweet spot with the nittos and get them to hook good, or invest in some M/T DRs or E/T Streets. Then after you get that, drive it like you REALLY REALLY want to get to the end of the track.
Old Jun 7, 2005 | 04:45 PM
but anyway you look at it i got a 13.6 on street tires with a 2.1 60 foot then 13.7 wiht 4.10 and nittos and a 2.0 so somthings still messed up
Old Jun 7, 2005 | 09:23 PM
toneloc12345's Avatar
I would say it had to do with the weather. I just raced my car and only got a 13.6@104mph with 2.2xx 60'. It was actually a dumb day to race with T-storms popping up because of 100% humidity.
There were several cars that I had seen race before that were all trapping about 3mph lower. I raced a 04 Mach 1 that was only trapping 98mph and a 01 Cobra that was trapping about the same.
TONY
Old Jun 8, 2005 | 05:20 PM
T/A lt1's Avatar
The weather and 4.10's maybe hurting you. You should have went with 3.73's with the auto. Goodluck Later Clint
Old Jun 8, 2005 | 06:52 PM
Violator's Avatar
I have to agree. 4.10's with an auto and stock coverter/no cam is overkill on the gear end. Should have left the gears alone and put a converter in it. About the only way those 4.10's are going to do you any justice is with a cam but then you'll need a converter to match up the cam.
They key to quick times is to match up cam/coverter/gear rpm power range and pull decent 60' s.
I have an M6, SI and bolt ons. 4.11's raised my LS1 mph from 107 last year to 111 this year so far but they work better in a stick car with no cam.
Mikie
Nov 10, 2003 01:06 PM
Chicago Z
3rd Gen / L98 Engine Tech
13
Sep 28, 2003 08:59 AM
TenaciousZ
Aug 1, 2003 04:06 PM
Highlander
Jul 1, 2003 07:45 AM
