V6 rear springs...worth it???
Old Aug 22, 2002 | 01:31 AM
LVZ2881's Avatar
Post V6 rear springs...worth it???
Tryin to hook my car up,low buck style.
any gains with a change to V6 rear springs for track only use???
James...
CZ28 Southwest Forum Moderator
1997 Z28 M6 T-top
bright purple metallic with quite a few bolt-ons.
13.69 @102.25 2.01 60ft
2200 ft elevation.
#3 Forever
MEMBER: LVFBODY.com
photos: '97 Z28 pics
Old Aug 22, 2002 | 09:45 PM
RichJ's Avatar
Post
I've got a pair if you are looking. $50. Just email me if you decide you want them.
RichJ
95Z
jonstnre@hotmail.com
Old Aug 23, 2002 | 07:05 PM
Jim98WS6's Avatar
Post
I've got them but I can't really tell any difference. BTW, they were only $20 for the pair at a junkyard.
Jim
Old Aug 23, 2002 | 08:13 PM
mod313's Avatar
Post
The right side spring was lighter on the V6 cars. The left side spring was the same as the V8 spring. For best results swap them from side to side.
Old Aug 26, 2002 | 09:26 PM
RichJ's Avatar
Question
<font face="Verdana, Arial" size="2">Originally posted by mod313:
The right side spring was lighter on the V6 cars. The left side spring was the same as the V8 spring. For best results swap them from side to side.</font>
What makes you think that the two springs should be different? I pulled a set of V6 springs off a V6 car in a salvage yard and they seem equally soft to me and look the same.
Rich
Old Aug 26, 2002 | 10:00 PM
GUMP's Avatar
Post
Not all V-6 springs are the same. There are a ton of different V-6 rear spring part numbers. I run one very soft V-6 spring in the drivers side rear and a Formula spring on the passenger side with an air bag. The real improvement comes when you loosen the front end up a little.
Good Luck,
Daren
Old Aug 27, 2002 | 09:51 AM
Pro Stock John's Avatar
Post
I don't think the spring rates are different from side to side IMHO.
I have a set of 1995 V6 springs I used to use.
Hope the following helps:
-i was told that 98 and newer v6 springs are the same spring rate as Z28's..
-v6 springs in back help the car squat.
-i think that v6 springs work well for drag radial cars, streetrace cars, and folks with small slicks.
-i took mine out when i went to bigger slicks the car was squatting too much and i have adjustable shocks/front back so the springs were no longer necessary
-rear v6 springs would help me on so/so tracks and i would sometimes hook a little bit better (1999) but once me and my buddies all got QA1 adjustable shocks we all hooked the same.
check out my personal website for some squat pics..
www.ls1tech.com/moderators/psj
1998 Formula | ARE 422ci iron block with Stage II heads | 40 lb Injectors | LS6 Intake | TTS headers | 3" ORP | Mufflex 4" Catback | MSD Wires | Whisper lid | SLP MAF | FLP level IV 4L60E | Yank TPE4400 | Moser 9"/4.10's | RT Torque Arm | HAL Shocks and Springs (front) | V6 Springs (rear), Alston 8 pt Rollcage | Airlift Airbag | Weld Prostars | ASCD Hood | 11.15@120.30mph 1.53 3625 raceweight LS1TECH.COM
[This message has been edited by Pro Stock John (edited August 28, 2002).]
Old Aug 27, 2002 | 08:15 PM
RichJ's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by GUMP:
Good Luck,
Daren
</font>
Old Aug 27, 2002 | 08:35 PM
RichJ's Avatar
Post
Oops. I meant to post that I agreed that loosening the front helps more. I added V6 front springs and shocks to my Z28 and the front end comes up a lot more. I'm switching to a stiffer set-up now so that my car will be better for autox and track events, so if anyone is interested in the V6 front set up drop me a line at jonstnre@hotmail.com.
Rich
96SilverRam
Nov 20, 2016 11:19 AM
HarleyZ28
Oct 5, 2015 06:23 AM
BLK1997Z28
May 1, 2015 12:23 PM
thenewkid
Apr 12, 2015 07:42 PM
