V6 Rear Spring Part Number?
Old Feb 9, 2007 | 08:38 AM
9T7 Trans Am's Avatar
Does anyone know the part number for a 93-97 V6 Rear Spring?
Thanks!
Old Feb 9, 2007 | 09:19 AM
Bolt-on Bob's Avatar
I don't know if it is different from GM originally but when I called Autozone and Advanced Auto recently they are showing the same part # for V6 and V8 cars. Don't know if that helps you or not ...
Old Feb 9, 2007 | 09:26 AM
Apparently GM has discontinued the V6 version of the spring and replaced it with the V8 version. These springs have 2 different spring rates. Looking more and more like I am going to have to go to the salvage yard.
Old Feb 9, 2007 | 09:21 PM
Stephen 87 IROC's Avatar
Measure the diameter of the wire on your springs. Find a V6 car and measure the diameter of the wire. The V6 spring should have a smaller diameter spring wire which will have a smaller spring rate.
Old Feb 14, 2007 | 01:35 AM
lookout4theyeti's Avatar
i have a pair of rear springs off my 2000 v6. I only replaced them because i lowered the car with eibach prokit. Im at school in toledo, and their back home in Cleveland, but pm me if your interested, i'll see what i can do
Old Feb 16, 2007 | 07:11 PM
SevenStars's Avatar
Pardon the stupid question but what is the point of v6 rear springs in a drag racing application?
Old Feb 17, 2007 | 12:52 AM
the lower spring rate lets them sag a little more on your launch, giving you more traction
Old Feb 17, 2007 | 08:32 AM
AL SS590 M6's Avatar
Moderator
It's a bandaid for not having your suspension right. And it works well enough if you can't afford the $$$ for all the proper pieces.
But letting the car squat is NOT the best way to transfer weight to the rear tires.
Old Feb 17, 2007 | 10:49 AM
but that is the reason why people run v6 springs tho am i correct? Even though its not the best way.
Old Feb 18, 2007 | 08:51 AM
Moderator
yes
parkers Z28
Mar 11, 2016 08:14 PM
FirebirdGT
Dec 13, 2014 10:25 PM
Brandon Wittmer
Dec 7, 2014 12:15 PM
