trunk mount batt kill switch problem
Old Nov 30, 2006 | 05:05 PM
romoranger's Avatar
ok. this is part 2 rear mount battery problems i guess. i got the ford solenoid and have that all wired up right. i have the starter going to the one side, then on the other i have my accesoires and a 1/0 cable that runs to one side of my switch. the other side of my switch i have my alternator (2 gauge) and my battery (3/0). on the correct post on the ford solenoid i have the ignition "hot" wire. i have even grounded the ford solenoid.
my problem is this. i have a bad ground somewhere i think. i go to put the negative cable on the battery and the darn thing wants to start welding stuff together. sparks like fire show. was there a ground that needed to be moved that i missed out on doing? i have the ground cables. in the rear the battery negative is on the innner fender, bolted onto the one piece of metal that sticks out for the spare. it has always worked for me in the past.
maybe, does the "s" side of the solenoid need a ground? what am i missing?
Old Nov 30, 2006 | 11:33 PM
Stephen 87 IROC's Avatar
Start disconnecting positive wires one at a time. Start with the hot wire to the alternator. If the ground still sparks then reconnect that hot wire and start pulling the switched wires at the solenoid one at a time until you find out which one is the ground wire connected to a positive. If the wire that you find is supposed to be a power wire then it's pinched or rubbed through to ground somewhere. Check to make sure your connections at the master switch are not touching ground. Simple electrical troubleshooting. Gee I wonder why so many cars burn to the ground because of poor wiring.
The wire going to the starter shouldn't be a problem since it doesn't become hot until the solenoid is activated.
Old Dec 1, 2006 | 08:33 AM
romoranger's Avatar
the wire i am using as a jump at the starter is 8 gauge power cable for car amploifiers, so i am woondering if that is arcing......
Old Dec 1, 2006 | 09:20 AM
romoranger's Avatar
found it. it was the alternator. somehow it was grounding out. thanks
redleader
Parts Wanted
Nov 13, 2016 02:57 PM
CARiD
Feb 9, 2015 09:35 AM
redleader
Jan 22, 2015 12:05 PM
squarehead
Nov 21, 2014 08:02 PM
x7x7
Aug 15, 2002 06:49 PM
