transbrake experts inside.....
Old Apr 9, 2003 | 09:52 AM
S.R.95Z28's Avatar
I'm working on a th350 with a hipster pro transbrake. Finally got it in the car and I have all gears. Reverse only works when the transbrake button is held (by design), but I'm not getting lock in first gear on the transbrake. I verified the manual valve phasing and believe it is correct. Does anyone have experience with this setup that could offer advise?
chad
Old Apr 9, 2003 | 03:53 PM
T/A lt1's Avatar
You need to check the voltage at the button for the t brake. Sometimes in my dads car we have to rev up the engine a little to engage the tbrake. So try puttin it in 1st hold the brake and stall it a litle then press the button to see what it does. Let us know whats up. Later
Old Apr 9, 2003 | 03:56 PM
S.R.95Z28's Avatar
thanks for the tip. I'll be working on it again tonight, so I'll post what I find. I think the modulator valve phasing is off a little.
thanks
chad
Old Apr 9, 2003 | 07:02 PM
S.R.95Z28's Avatar
Angry
Got the brake to hold over 5000rpm several times. As soon as I put it in reverse and cycle it in reverse, it won't hold 3000rpm in low gear. Guess I'll have to call hipster tomorrow..
RUENUF
Mar 13, 2016 03:37 PM
C4m4roJoe
Jul 19, 2015 10:59 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
chevyguy3
N2O Tech
Nov 8, 2002 09:48 PM
