traction and mph
Subscribe
May 6, 2011 | 12:42 PM
So I just ordered my DRs, LCAs, EWP and A/C delete today. What kind of mph improvement do you think ill see from those power freeing mods/weight reduction? I'm also removing the rear seat belts this week too. Also, will added traction improve my mph? I was averaging about a 2.35 60' time on street tires and had to keep backing out of it in 1st. (first day they were open, DR guys weren't doing much better)
Car is a bolt on, cammed, stalled, geared LT1 with light hand porting on the heads.
Reply
May 7, 2011 | 08:30 PM
Re: traction and mph
Traction generally will not get you MPH.
It will reduce your ET.
So say your running 13.3 at 104 and a 2.3 60ft.
You get a better 60ft say a 1.9 the 4/10th on the line will be worth up to 6-7/10 on the top end.
You now run a 12.6 or 12.7 at 104/105mph.
MPH will be improved if you make more power.
Reply
May 9, 2011 | 07:00 AM
the weight reduction combined with the EWP shoild get you about 1 MPH. And as Tom just said the traction will get you ET.
Reply
May 9, 2011 | 12:45 PM
That wasn't the case for my car. Years ago first time out I did a best of 13.3 @103. Went back with only DR's and did 12.8 @105.
Reply
May 9, 2011 | 02:45 PM
I figured that the excessive wheelspin through all of first and half of second would slow you down a tad up top.
Reply
Jun 16, 2011 | 08:09 PM
Yep. I have changed nothing on my car many times and just by getting more traction the MPH improved 1-2 mph. 12.2s@113 to 12.1s@115
Reply
Jun 17, 2011 | 09:08 AM
I gain 5 mph when I can leave off the transbrake on a race tire vs. Peddling it on a street tire. Also I see a .7-.8 second ET drop.
Remove front sway bar? Always a good idea.
With traction you could be .6 quicker in the 60'. So... about a second faster that whatever the hell you ran with a 2.35 60 foot.
Reply
Feb 27, 2012 | 11:17 PM
I always lost MPH with a better 60' I'm not talking drastic differences but .3 was good for. 6 on the back end but I was always 2-3 MPH faster lighting em up from when i hooked well
Reply
Subscribe
