Track Times
Track Times
I made the first trip with the car Saturday. The car has 3.73 gears, 58 mm TB, LT4 Hotcam, and 1.6 RR. The PCM is stock, havent even changed it for the gears so it hits the rev limiter before shifting. This was on street tires and the car spun a little. What would these times be in the 1/4 mile, 1/4 mile MPH. Do any of you know what the car should run if tuned and with a good converter and sticky tires. Thanks
First Pass: Second Pass:
60': 2.117 2.100
594': 8.368 8.410
1/8 ET: 8.931 8.980
1/8 mph: 79.92 78.93
60': 2.117 2.100
594': 8.368 8.410
1/8 ET: 8.931 8.980
Re: Track Times
I don't know if this helps but I ran a 8.957-1/8, when I ran my 13.930-1/4,but with the hotcam you would probably start gaining on the top end of the track so you would end up running faster than 13.9 and I'd say with a good tune and a converter you would see those times drop alot.
teedoff59
Aug 8, 2002 01:36 AM
