Track opens soon need guesses?
Old Mar 4, 2006 | 05:26 PM
  #16
1SlowFormula's Avatar
Re: Track opens soon need guesses?
Originally Posted by Nick-LT1
My car last your with morso intake mac mids, and slp loudmouth no tune on street tires in july ran like 3 13.5 at 102mph and a few 13.6 with 2.0 60'. The car had it share problems later that year with a high miss which later my fuel pump went out then after that my opti went out. So i dunno maybe it could have ran even better then that. I live in St. Louis and i go to Gateway Internation which is sea level and i except it to be in the 50's for my first run. My COMPLETE mod list would be Morso cold air, trick flow elbow, tb bypass, LT4 knock, mac mids, no cat, loudmouth, no egr, no air pump, 2800 midwest, transgo shift kit, tranny cooler, 3.73's, 1.6 rr, k-800 springs, cc306 cam, new timing chain, harden pushrods, decent tune, and will be running of BFG drag radials. I am really hoping for mid 12's but i will just be happy to run anywhere in the 12's. THANKS!!!!
From all that I gather that you ran 13.5 - 13.6 then added:
  • Converter, shiftkit, suspention components, and tires -.2 in your 60'
  • Cam, 1.6 RR's and a tune +30/40ish HP and also cutting about .1 off your 60'
My guess if everything was similar in weather the day you go to the track then you should drop to at least a 1.6-1.7 60' which would take you down to ~13.1 with nothing else, then add more power say 40 HP, and your gearing then you are looking at close to 12.5 or so as a comparison to what you ran before. Now through weather and repaired issues from the last run and that could add up to more on the topend pushing you deeper into the 12's.
So if I were a betting man and you suspension was set up correctly, then I would wager on you getting about a 1.63 60' and run a 12.37 @ about 106.5, what do I get if I win???
Old Mar 7, 2006 | 10:56 PM
  #17
Nick-LT1's Avatar
i would be happy as hell if my car ran that good!!!
Old Mar 8, 2006 | 07:05 PM
  #18
When are you going to the track?
Old Mar 22, 2006 | 01:30 PM
  #19
Nick, Did you ever make it to the track???
Old Mar 23, 2006 | 06:37 PM
  #20
DarkHorse's Avatar
Similar mods to my combo pre SC except:
I have a smaller GTP 4 cam 226/236 534/560 114lsa, I have LT's+E Wp but less gear (3.42). With 1.77 60's I went 12.3's-12.4's @ 110-113 in good decent weather.
Good weather, car running right and traction you should go low-mid 12's. My shorties were a big bottleneck on my car.
http://media.putfile.com/1236---Dads-gonna-be-happy
http://media.putfile.com/1244-Loudmouth---April-2k5
DirtyDaveW
Dec 1, 2016 05:37 PM
Feffman
Jul 2, 2015 06:52 AM
njspder
Middle Atlantic
May 4, 2015 06:48 AM
192cobra
Jan 26, 2015 12:12 PM
