Track elevation?
Old Sep 7, 2005 | 01:40 AM
blind527's Avatar
Track elevation?
If a tracks elevation is 320 ft. is that sufficient? Just curious because I'm comparing what I ran before to now with different elevations.
Old Sep 7, 2005 | 07:59 AM
Stephen 87 IROC's Avatar
Re: Track elevation?
Sufficient compared to what? Technically, that can still be considered sea level elevation.
Track elevation doesn't mean much. Taking into account the elevation, temperature, barometric pressuse and humidity you get a density altitude. You can easily have a lower density altitude at a higher elevation track in good weather than you can have at a lower elevation track in poor weather. A hot sunny day isn't considered good weather.
Old Sep 7, 2005 | 12:46 PM
blind527's Avatar
Sufficient compared to about 1200 feet. It was about 1200 feet at the track I went to last time at about 90* and high humidity. This Friday, it's supposed to be a night race, will only be about 65-75* with low humidity at 320 ft. elevation.
Old Sep 7, 2005 | 02:39 PM
If nothing changed except the altitude, you'd run about 0.15-seconds quicker at the lower altitude. But as Stephen points out, you need to consider the affects of temperature, absolute humidity and barometer as well.
Louey
Pacific
Oct 1, 2015 12:37 AM
NewsBot
Sep 16, 2015 10:30 AM
94ZinEdgewater
Sep 8, 2015 09:55 PM
Louey
Pacific
Sep 1, 2015 07:19 PM
Louey
Pacific
Aug 25, 2015 01:53 AM
