Tips - Looking to improve E.T.
Old Jun 9, 2005 | 01:10 PM
1quickTA's Avatar
I am really disappointed by my E.T. You can look at my sig. to see my times and my mods. Can anyone give me some tips as to tire pressure, launch techniques, shift points and whatever else you can think of? Also, any estimates on what I SHOULD be running? FYI- I run street tires. I am also planning on getting SFCs and LCAs soon because I know that is a weak point on my car. Any advice would be GREATLY appreciated.
Old Jun 9, 2005 | 01:13 PM
Knowklew's Avatar
Re: Tips - Looking to improve E.T.
what are you 60ft times?
Old Jun 9, 2005 | 02:05 PM
1quickTA's Avatar
Off memory, I believe that I was pretty consistant with low 2.2's. What should I expect with a good launch on street tires and how would you recommend getting there?
Old Jun 9, 2005 | 02:30 PM
Knowklew's Avatar
kind of a rule of thumb is that each tenth you can take off your sixty will equate to almost two tenths in the quarter. Just practice your launches, work on getting that 60ft down to a 1.9 or 1.8.
Old Jun 9, 2005 | 02:34 PM
1quickTA's Avatar
I'm looking for launch techniques. Have any? RPM to launch from, letting out clutch technique?? And the 1.9 or 1.8 60' times you mentioned, could that be expected on street tires? What psi in the tires (I ran BFG KDW at about 22 or so psi)?
Old Jun 9, 2005 | 09:59 PM
Knowklew's Avatar
Well my car is an automatic so i dont have many launch tips for you. I pulled 2.0 on Goodyear Eagle GSC's......worst tire ever!!
Old Jun 10, 2005 | 04:56 AM
rskrause's Avatar
Moderator
Your tire pressure is too low. Unlike bias ply race tires, street radial tires should be run at a normal pressure, maybe just a bit towards the low end of the normal range. If you can cut sub 2.0sec 60' times on street radials with an M6, you are doing good, that's a reasoanble goal. How to do it? Practice, practice, practice. In general, you are going to want to come out at fiarly low revs (1,500-2,000) and slip the clutch while gradually rolling on to the throttle in first. What works best will depends, at least partially, on track condition. Be sure you line up "in the groove".
Rich
Old Jun 10, 2005 | 06:41 AM
1quickTA's Avatar
Thanks Rich, I appreciate the advice.
Old Jun 10, 2005 | 11:51 PM
nonojoe66's Avatar
is that realy true? 1 tenth off the 60ft can be almost 2 tenths off the quarter mile time? i cant see how that can be true, that would mean that if i can pull a 1.6 60 ft time i would be runing mid 12s whereas with my 2.3 60ft i ran a 13.8?
Old Jun 11, 2005 | 07:04 AM
rskrause's Avatar
Moderator
It is a decent rule of thumb, but it has its' limits. Only applies for for 1-2 tenths.
Rich
13qtr
Oct 28, 2016 08:11 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
autoxr166
Sep 25, 2015 04:21 PM
NewsBot
Sep 14, 2015 08:50 AM
CARiD
Sep 7, 2015 08:21 AM
