Those with 4.10 gears come in.
Old Mar 30, 2007 | 01:16 PM
T/A lt1's Avatar
I am finishing up my car this weekend and put a Moser 12bolt with 4.10's in it. I always ran high gears (3.42's,3.55's) and wanted to know what rpm you guys cross at, mph and what size tire? I know it will cross on mtotr but don't think it will be able to cross on n2o with a 7k rpm limit. I have 28" M/T Drag radials and thinking about maybe going with a 30" tall tire for spray. I plan on running over 136mph on n2o. LMK Later Clint
Old Mar 30, 2007 | 07:22 PM
AL SS590 M6's Avatar
Moderator
Well I'm not running the MPH that you are but my set up is 4.10s, PT4000 converter, Hoosier QTPs 27-11.50x15 and I cross the line at 6500 @ 120 mph.
Stepping up to 28s this year. Trying the Hoosier 275/60x15 drag radials.
Old Mar 30, 2007 | 08:15 PM
Steve69SS396's Avatar
I'm running 28 X 10 slicks, 4.10 gear and a 4,000 stall converter and I cross the line at 130 at 7,400 rpm.
Old Mar 31, 2007 | 01:01 AM
xpndbl3's Avatar
probably need a 29.5 tire due to converter slippage. But the only way to know for sure is to try it out on the 28" tires and if you run out of RPM then you'll know. RPM calculator I just checked said 7k rpm, 28" tire, and 1:1 trans gear should be good for 142 mph without taking into account converter slippage.
Old Apr 1, 2007 | 12:03 PM
T/A lt1's Avatar
Thats what I was thinking about 125-127mph@7k so I will probably just swp to 3.73'sonce I get the car to run up to par on motor but it should run hard to the 1/8th mile with the 4.10's and n2o. I'll let you guys knowwhat it does shortly. later Clint
Old Apr 4, 2007 | 03:26 PM
Split-Bumper's Avatar
We run the M/T radials 295/65/15 with 4.10's @ 157mph at 7400 with 3740lbs on its back!
Old Apr 4, 2007 | 09:00 PM
Ken95Z28's Avatar
Clint,
28" Tire, 4500 Converter, 6500, trapping 122.
Weather should be good Friday Night, hopefully it will dip in the 10's.
Old Apr 5, 2007 | 04:34 PM
T/A lt1's Avatar
Thanks for the info guys. I don't see how you can get 157mph@7400rpms with 4.10's. How tall are the tires and the converter must be really effficient. Later
Old Apr 5, 2007 | 06:31 PM
30" with growth, and yes when you pay a grand for a converter it better be efficient!
Old Apr 10, 2007 | 08:20 AM
marshall93z's Avatar
I have seen some for that much and more that wasn't.
Drtryder
Apr 22, 2015 04:17 PM
camy 1993
Feb 1, 2015 07:16 PM
Noer
Parts Wanted
Jan 19, 2015 10:19 AM
GRN96WS6
Sep 8, 2002 10:45 PM
funina91ss
Aug 6, 2002 11:20 PM
