TH350 conversion, how did you get the speedo to work?
I haven't worked that out yet. My speed reads way high. It is unpluged for now. I hope LT1 edit will correct the reading. I installed the ring reducer and stuff listed in other postings but I still have the problem. Maybe my 4.11 gears has something to do with it.
If you have an OBDII car you can hook up to the ABS stuff. if you have an OBDI car then it is a bit more difficult....I had to get a set up from Dakota Digital for less than $110 and it works. i have to fine tune it but i know how fast I am going within a couple of MPH.
email me or post here and I can give you more info as needed. ie part numbers from Dakota Digital and how i set mine up.
