Street Tires?
Hey I just got some Toyo Fz4, that I will be using ocassionally for racing, now what is a good launch point for street tires? And do I need to heat the up at all? I had completely bald tires before and I had to basicly launch at idle and would loose traction shifting into second (the whole *** end would swing out.) So any help at al lwould be great thanks.
Nope, don't heat them up like you do with slicks or DR's. Just do a lite burn to knock off the pebbles. You can try to lower the pressure if you like but with the stiff sidewalls on them it won't do that much good.
1995 Z28 A4 3.42 Best ET(12.205@109.50) LT4 Hot Cam, 1.6RR's, K&N FIPK, 85mm MAF, Hooker LT's, Dual Exhaust, Yank ST3500, TransGo Kit, CSI WP, Hoosier Slicks, 6-point Wolfecraft and Ed Wright Programming
Ken's 1995 Z28
F-Body Fastest List
"Never be afraid to try something new. Remember that amateurs built the ark. Professionals built the Titanic."
Ken's 1995 Z28
F-Body Fastest List
I put my 255's down to 19 psi at the track. I might try about 18 psi next time (and hope for some sub-2 second 60 foot times) but you have to keep in mind that your tires still have to hold up when you are passing through the traps at high speeds.
92 RS carb'd 357 5-speed T-tops maroon w/ black cloth interior
650 cfm Double Pumper, stealth intake, dual 12" radiator fans, 10" auxiliary pusher fan, 5" X 12" power steering cooler, 204/214 cam duration @ .050", 420/443 valve lift, 1.75" headers, no cat, 3" PaceSetter catback w/ dual 2.5" tailpipes, 3.73 gears, posi, 245/50/ZR16's up front, 255/50/ZR16's in back
2.070 60 ft, 9.9 @ 71 (1/8), 15.4 @ 87 (1/4) <--old times
100% American (you damn right)
Boss002
May 20, 2015 12:55 PM
