Stock A4 launch technique
Old May 16, 2004 | 11:11 AM
blunto's Avatar
Hey I was curious to know what you guys with stock or semi stock A4 LT1s with 3.23 gears are using as a launch technique. Right now I brake torque to about 1800, and spin like a **** Is there a better way to launch my car, or do I just need to upgrade from the crappy salad shooters?
Old May 16, 2004 | 01:56 PM
Kataklysm's Avatar
I cut a 2.0 60' on street tires by stalling to 1100-1200 then just dropping it....this was also on 7 cylinders though BTW, I had 25 psi in the rear tires.
Old May 16, 2004 | 05:17 PM
mrr23's Avatar
i just sit there at idle. then when the lights go down, give it half throttle. if not spinning, then start giving more gas. now, on drag radials, i can just floor it from an idle and have no spin. stock converter and 3.23 gears in both of my cars. 99 formula and 99TA.
1999 Pontiac Formula
1999 Pontiac Trans Am
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
redleader
Wheels and Tires
Jan 22, 2015 04:20 PM
mark0006
Dec 25, 2014 09:50 PM
Victory Racing
Apr 19, 2010 06:08 PM
