So whats my car gonna run tonight...
Old Apr 19, 2006 | 09:00 AM
Bow94z's Avatar
Best time to date is 14.0@102 w/ 2.2 60' on my aftermarket 17's w/ crappy street tires..
Tonight im running stock 16's all around with BFG Drag Radials on the rears.
Car has simple bolt-on's and gears...everything listed in sig..N20 will not be used tonight
Car puts down 267/300 on the dyno..
13.60's possible?? i think so
Old Apr 19, 2006 | 10:36 AM
matt65's Avatar
Re: So whats my car gonna run tonight...
I think you can get 13.6.
I trapped 104 @ 13.6 in mine (street tires cold track) and the lack of traction was a factor.
A sticky track and good tires can have a good effect on e.ts
Old Apr 24, 2006 | 07:08 PM
matt65's Avatar
So,
How did she run?
Old Apr 24, 2006 | 10:55 PM
Bow94z's Avatar
Well I wasnt happy at all..but Consistant none the less! My 60's were there, just felt like the car was giving up on me up top! I think it's the 140k mile fuel pump giving up on me
1st Run
R/T: .294
60': 2.1
1/8: 9.4
MPH: 77.01
1/4: 14.476
MPH: 98.38
2nd Run...power shifted the hell out of it 1st-4th
R/T: .000 <<<<ooohh YEAH!
60': 2.0
1/8: 9.1
MPH: 77.42
1/4: 14.1
MPH: 98.42
3rd Run me and a fox body both red lighted this run he ran 14.0@96mph
R/T: -.186
60': 2.0
1/8: 9.1
MPH: 77.34
1/4: 14.1
MPH: 98.38
Old Apr 25, 2006 | 06:49 AM
6SpdLT1Z's Avatar
your def lacking on the top end.. My fuel pump went out at 134k. How much fuel pressure are you getting at the schrader valve.
Old Apr 25, 2006 | 08:41 AM
Bow94z's Avatar
i gotta throw the test guage back on there again...over a month ago it was reading fine...the pump is the only thing i can blame at this point, cause this car has always trapped over 100..time to call racetronix!
Old Apr 25, 2006 | 09:58 AM
TedH's Avatar
I'd check the air filter and fuel filter before going for the fuel pump. The mph dropped off big time. Any idea of the weather conditions? 4 mph is a lot. One burnt plug wire can cause that type of power loss as can a fouled plug. Do the simple things before spending money.
Old Apr 25, 2006 | 11:00 AM
Bow94z's Avatar
OPTI is like new, I check for any burnt wires..nothing, they are fairly new aswell..I cleaned my SLP airfilters two days before I went to the track..fuel filter has like 15k on it, i might change that too, but I am still putting the problem on the Fuel Pump
it was like 60 degrees outside with some light wind..the 102mph run was in like 40degree weather at the same track
www.racewaypark.com is where i raced at
bernie1951
Dec 10, 2014 10:03 AM
nophix
Nov 30, 2014 10:26 PM
USAirman93
Nov 24, 2014 03:37 PM
Snoman73
Nov 17, 2014 07:22 PM
supercharged94Z28
Feb 24, 2003 10:22 PM
