Slick Sizing needed
Old Mar 22, 2004 | 07:15 AM
IDOXLR8's Avatar
Slick Sizing needed
Ok I need some recommendation on tire sizing for my 93 Camaro. The car makes over 700 rwhp at 6200 rpm. It has a Moser 9-in with a 3.50 gear. The tranny is an M6 with the following specs.
3.36 1st gear
2.07 2nd gear
1.35 3rd gear
1.00 4th gear
0.80 5th gear
0.62 6th gear
I need to know how tall of a tire I should go with. These tires will be mounted on 15x10 Bogart RT Bolted wheels. Also what would you guys recommend for front runner (15x4 skinny)? Any recommendations on brand will also be appreciated. If it matters my car is supercharged. Thanks in advance.
Old Mar 22, 2004 | 10:40 AM
rskrause's Avatar
Moderator
Re: Slick Sizing needed
3.36 1st gear
2.07 2nd gear
1.35 3rd gear
1.00 4th gear
0.80 5th gear
0.62 6th gear
I think 27" would work well, also less fitment issues than with a 28" I am using a 27" Hoosier QTP with the same wheels. 28" would probably also be ok. 26" would be too small.
Rich Krause
Old Mar 22, 2004 | 10:59 AM
IDOXLR8's Avatar
Re: Re: Slick Sizing needed
Rich Krause
What kind of modifications did you do to get the 27" slick to fit? Thanks
Old Mar 22, 2004 | 12:24 PM
Pro Stock John's Avatar
I'd run a 28x10.5x15 slick if you want to run any sort of decent ET.
Old Mar 22, 2004 | 02:28 PM
rskrause's Avatar
Moderator
Mine are pretty decent with the 27" and a 3.42 gear. No mods really needed for 27". I did trim the rear bumper cover a little to ensure clearance with tire growth.
Rich Krause
Old Mar 22, 2004 | 02:42 PM
Rich you are T400 right? He's stick, he needs all the sidewall he can get I think. Then again if his car is a tank he could probably run something okay on 27's.
Old Mar 22, 2004 | 03:29 PM
blkchevyz's Avatar
http://www.f-body.org/gears/
Old Mar 22, 2004 | 09:03 PM
10.90streetcar's Avatar
If you are truley making 700 RWHP and with that steep first gear, Your gonna need the tallest tire you can stuff under that thing.
Old Mar 23, 2004 | 06:42 AM
IDOXLR8's Avatar
Thanks for the advice guys. I am thinking the car will weigh 3650 lbs with me in it. My car made 705 rwhp with the twin high flow intercoolers. Car had more in it but kept blowing off intercooler pipes. Since then I have gone with a big front mount Spearco intercooler and am running no filter on the back of the blower. I am hoping the car will pick up another 50 rwhp. I guess I will have to wait and see.
HectorM52
Jul 30, 2017 11:46 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
