Skinnies and brakes
Old Jul 2, 2007 | 02:55 PM
  #16
Javier97Z28's Avatar
Moderator
Originally Posted by The Engineer
PS: I'm still headed to WPB next month.
Sounds good dude, I'll be here. I think I passed you my #.
Old Jul 2, 2007 | 09:53 PM
  #17
The Engineer's Avatar
Yes, I've got your phone number. Also, check-out this link and the No-E finals from last Saturday. Almost!
http://www.okthunder.com/results/Bra...030,%2007.html
WD
Old Jul 10, 2007 | 07:56 PM
  #18
rock1501's Avatar
convopro`s clear everything and look good
Old Jul 17, 2007 | 04:45 PM
  #19
89385formula's Avatar
Thanks for the compliment! I have the Weld Alumistar 2.0s front and rear.
WD
Car and wheels look sweet!
Old Jul 17, 2007 | 05:06 PM
  #20
DarkHorse's Avatar
Telstars fit - no mods
Old Jul 18, 2007 | 08:24 AM
  #21
Z-RATED94's Avatar
Yes it does, but I like that trailer too.
Old Jul 18, 2007 | 08:45 AM
  #22
Juiced91Z's Avatar
almost any skinny fits if you go with the 1.75" backspacing. Though Bogart's, or the XP series from Weld are designed for larger brakes, I have LS1 front brakes on my car and i run the M/T ET Drag front without a problem
Old Jan 7, 2008 | 04:29 PM
  #23
Vicious95Z28's Avatar
I Know This Is Old But I've Come To The Stage Where I Either Want To Research Drag Brakes Or Solutions To Making Drag Type Wheels Work With The Stockers. Basically It Seems As Though A 5/16 Spacer Is All That's Needed But Doesn't It Caouse The Wheels To Stick Out In The Front? Or, Is It Moe Or Less The Size And Type Of Tires Being Used That Makes Them Look That Way?
Old Jan 8, 2008 | 07:05 PM
  #24
CamaroRacing12's Avatar
ok not meaning to thread hijack but i have a few questions about the 15x3.5 prostars wat backspace is required? All u need is a 5/16 spacer? with the spacer will these fit the stock studs? they look kinda short....
Old Jan 8, 2008 | 07:52 PM
  #25
Gear Jammer
Guest
Posts: n/a
Please remember also that the Bogarts are NOT recommended for street use. They are extremely light; one curb and they're junk! Holeshot makes a nice wheel like the Bogarts that is lighter than the Welds. Very hight quality wheel. I had the Holestar model on my '95 Impala SS and they cleared that set-up just fine. I plan to use them on my Z28 as well. Also, I drove them on the street a couple times and they lived under the 4,000 lb. B-body.
Old Jan 9, 2008 | 11:34 AM
  #26
There is an FAQ stickied at the top of the Wheels & Tires forum topic page, which includes a post which answers your questions in detail.
Old Jan 9, 2008 | 02:45 PM
  #27
Where can these be found?
magman
Apr 15, 2016 03:08 AM
RUENUF
Mar 13, 2016 03:37 PM
IndyZman
Oct 22, 2015 02:17 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
maverickmk
Sep 1, 2015 09:17 PM
