Should I worry about breaking something.
Old Dec 16, 2003 | 12:38 AM
S.J.S.'s Avatar
As far as my rear end. I plan on running my mods below with sticky's. The only thing stock on my car is the rear end.
thanks.l
Old Dec 16, 2003 | 08:00 AM
TedH's Avatar
With a stroker and stcky tires I would be investing in a 12 bolt.
Old Dec 16, 2003 | 10:34 AM
red's Avatar
red
I predict that the only stock item on your car will need to be replaced.
Old Dec 16, 2003 | 11:19 AM
KCFormula's Avatar
If I were you I would be more worried about your transmission. I would get a girdle for the rear end and it should be fine for a while.
Old Dec 16, 2003 | 07:52 PM
RacinLT1's Avatar
i forsee the stock rear having a short lifespan with that combo and stickies.
The trans looks to be built,so you should be fine there.
Old Dec 17, 2003 | 05:30 AM
S.J.S.'s Avatar
K....first off, what the heck is a girdle? Didn't do much research on rear ends before I built this ****.
thanks.
Old Dec 17, 2003 | 08:12 AM
RacinLT1's Avatar
rear end girdle is a replacement cover made from cast alum with 2 bolts that are uses to preload the carrier caps.
Old Dec 17, 2003 | 11:35 AM
TedH's Avatar
Actually, on my very first pass after installing the stroker the transmission slipped... It was a TCI 700R4 with a 3600 stall.
Old Dec 17, 2003 | 04:50 PM
S.J.S.'s Avatar
where do you get those girdles from????
Old Dec 18, 2003 | 10:23 AM
TedH's Avatar
Try http://www.summitracing.com
I think it is part number SME-8510400
This will only help a very little bit... I broke the rear a couple of times with a cover before I installed the stroker. I finally put in a 12 bolt.
Old Dec 18, 2003 | 10:26 AM
S.J.S.'s Avatar
what kinda mods did you have to do to install the 12 bolt????
Old Dec 18, 2003 | 07:33 PM
RacinLT1's Avatar
no mods needed for a 12 bolt or a 9". unbolt the stock rear,bolt in the new 1.
Old Dec 18, 2003 | 07:57 PM
Stephen 87 IROC's Avatar
After you purchase an aftermarket bolt in one. Expect to pay around $2000 for either. A junkyard 12 bolt or 9" will not "bolt in".
Old Dec 19, 2003 | 01:51 AM
scott9050's Avatar
The 9 inch Ford is stronger. From what I have heard the 12 bolt is about the same design and strength as the Ford 8.8. You won't break the 9 inch Ford rear.
Old Dec 19, 2003 | 10:16 AM
TedH's Avatar
I got my 12 bolt from here: http://www.moserengineering.com
Moser has provided me excellent service. The added strength of a 9" isn't a factor until you start pushing the design limits in my opinion.
