shelf cam, 6spd, N/A, stock PCM.....
Old Oct 5, 2005 | 06:15 PM
Z284thgen's Avatar
whats the fastest thats been produced
cam= 304,305,306 846,847, etc NO custom grinds one that can be looked at in any manf catalog and ordered
6spd= yeah thats right still shifting and banging the gears
N/A= if you dont know what that is please dont post up in this thread
stock PCM= no FAST,DFI, etc.....
any stroke,heads,cubic inch's, intake system
just looking to see how fast a SHELF CAM has been so far in a 6spd, N/A stock PCM'ed trying to get mine into the 10's im close now
Old Oct 5, 2005 | 09:14 PM
Kreinmc's Avatar
Re: shelf cam, 6spd, N/A, stock PCM.....
The 306 is probably the best and the 847 is a close second. The 847 has better lowend and midrange than the 306 and will be a better choice if you drive the car a lot.
Old Oct 5, 2005 | 11:20 PM
Dave69Z's Avatar
He is already running an off the shelf cam much larger than a 306. He is just looking to see how fast a 6-Speed car has been on the motor with the stock PCM with an off the shelf cam versus a custom ground cam.
Dave
Old Oct 5, 2005 | 11:38 PM
blksunshine's Avatar
what cam are you running now 4thgen?
Old Oct 6, 2005 | 05:16 PM
Z284thgen's Avatar
looking for ET's & mph
dave its not that big of a cam i think i just got a decent combo going here
car currently has a part#109841 cam installed with 1.6rr's
when i get off the road from work gonna get with the head porter and see bout getting a custom grind cam with a much more aggressive lobe's then what the shelf cams run
Old Oct 8, 2005 | 09:04 AM
T/A lt1's Avatar
What brand is the cam you are currently running and what are the numbers@50? duration 23X/24X? lift 57X/60X? My car and yours would be a really close run huh? Look at my sig.(11.24@120.8mph) except I am an auto with a higher gear setup for n2o. I plan on running 10's N/A with my new heads also in a couple weeks. Later and good luck.
Old Oct 8, 2005 | 02:02 PM
Z284thgen's Avatar
when was that time ran tulsa has been getting some killer DA's and im stuck in TX working until thanksgiving ( hopefully sooner) .... its a crane cam
still planning on leaving the 6spd until it breaks then comes the auto......
Old Oct 9, 2005 | 12:05 AM
z284thgen are you on a stock block?
T/A LT1 changing combo's again , who is doin the heads?
Old Oct 9, 2005 | 09:06 AM
Z284thgen's Avatar
nope its a stroker
Old Oct 9, 2005 | 10:31 AM
T/A lt1's Avatar
Oh, mine is a 355" LT1 and I ran those times early this year when it was about 500' above sealevel. Blksunshine Lloyd Elliott is doing some new Trickflows and a LT4 intake. Should make some more power we will see. Later
Old Oct 9, 2005 | 10:44 AM
Z284thgen's Avatar
this poor ol shelf cam is no where near enough cam for the heads and CI.... but thats taken care of i got a new one coming custom ground to the heads and a good ol steve quinn LTx intake going on top of it then we will see how she runs
Old Oct 10, 2005 | 02:49 PM
SBCGENII's Avatar
I think he ran that before the weather got good.
DirtyDaveW
Dec 1, 2016 05:37 PM
canbaufo
May 25, 2015 12:01 PM
Roadie
Feb 16, 2015 10:34 AM
MyShibbyZ28
Feb 14, 2015 12:05 PM
TYLER94Z28
Dec 3, 2014 07:05 AM
