Setting Pinion angle on BMR TA
I read the directions but after getting in there and putting the angle finder on the driveshaft I think I got 4 degrees postive?
If the needle is left of zero it is negative correct? If the needle is right of zero it is positive?
But the mounting plate on the rear end is hard to get to and I don,t think the reading I got is correct, It seems to be 8 degrees positive. So I take 8 degrees positive and subtract 4 degrees positive I would have 4 degrees positive,????????
I can get the angle finder on the TA mounting plate pretty easy, is it ok to measure there?
I am totally lost.
If the pinion on the rear is pointing up that is negative or positive?
I am totally lost.
oldschool
02-09-2016 09:21 PM
