Semi Bench Racing Question
Old Dec 11, 2006 | 03:16 PM
godspeed1976's Avatar
The last times on my car were run by the previous owner in Indiana. He was running 13.6@102mph on street tires. I am curious what kinda time you think I can pick up going to 3.73's from my 3.42's and also from 275/35/18's to 255/60/16 MT ET Streets.
I am just curious as to what you more seasoned racers think the gain would be. I have the stock stall, and am in Montgomery, AL. I am thinking the lower elevation, better gears, and slicks should get me pretty close to the 12's.
My current lis of mods are:
Engine/Trans:
Lingenfelter Cold Air Intake
TrickFlow Ceramic Coated Intake Elbow
LT4 Knock Module
1LE A/C Delete Pulley
ARP Head Bolts
O2 Sensor Extensions
Pacesetter Ceramic Coated Longtube Headers & OFF-ROAD Y-pipe
3.42 Rearend
Hooker Cat-Back Exhaust System
Summit 3" Cutout
DMH E-Cutout
MadZ tuned
Taylor 8mm cut to length wires
NGK TR55 plugs
Removed EGR and AIR
Chassis / Suspension:
Strano Revalved Bilstein HD Shocks
Eibach Pro-kit lowering springs
BMR Tubular Subframe Connectors
Prothane Motor Mounts
98+ Front Brakes
Lakewood Boxed Rear Control Arms
Lakewood adjustable panhard rod
SJM ABS Delete Kit, Line Lock, Wilwood Prop. Valve
Energy Suspension Poly Transmission Mount
Welded LCA Relocation Brackets
MOOG Front Lower Ball joints
MOOG Front Lower Control (A-Arm) bushings
Rims and Tires:
American Racing Series 699 "Rebel" Wheels
Kuhmo Ecsta 712 275/35-18
Old Dec 11, 2006 | 08:48 PM
2 tenths? Im not looking for anything solid just an educated guess.
Old Dec 11, 2006 | 09:51 PM
CamaroRacing12's Avatar
i dn it matters on the driver u might get the same worse or better...
Old Dec 12, 2006 | 08:09 AM
Thank you for your reply. I know times will greatly vary between drivers.
I was looking more for experience. Things like..."when I switched to 3.73's it helped me pick up some much time." or "When I went from my street tires to ET Streets I picked up an extra so and so."
I know it is just hypothetical, and perhaps I should have worded things differently in the thread title. "How much ET did you gain when adding gears, or slicks."
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Injuneer
Dec 15, 2014 09:36 AM
Louey
Pacific
Dec 1, 2014 04:16 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
