Safety Wire
Old Jan 16, 2008 | 10:19 AM
white97T/A's Avatar
Safety Wire
I was looking through a Summit Racing catalog and saw a product called "Safety Wire." From reading the description it looks like it has something to do with keeping bolts from loosening. For curiosity sake, could someone enlighten me as to how safety wire is used?
Old Jan 16, 2008 | 04:17 PM
Wire is run through holes in bolts or nuts, to prevent them from loosening.
http://www.whizwheels.com/Tips/safetywiring.html
Old Jan 16, 2008 | 07:01 PM
The Engineer's Avatar
I believe safety wire originated in avation industry and remains the main area of usage.
WD
Old Jan 17, 2008 | 07:15 AM
AL SS590 M6's Avatar
Moderator
WD
It's used extensively in the manufacturing arena. Stamping presses, robot end effectors, over head cranes and rail systems, any part that could vibrate loose.
Old Jan 17, 2008 | 08:04 AM
tomcowle's Avatar
NASCAR too, I've been in several shops and look at different applications where it was used. They don't want a black flag for any "cheap" excuse.
Old Jan 17, 2008 | 09:57 PM
Stephen 87 IROC's Avatar
Drill a hole through the head. Install wire through hole so that if the bolt loosens, the wire gets tighter. One bolt is wired to another for an anchor. A minimum of 2 bolts is required. One long piece of wire is used to secure a series of bolts then the 2 ends of the wire are twisted together if they meet back up.
As stated above, it's big in the aviation industry to keep bolts from vibrating loose. Even with the improvements with products like Loctite, bolts can still loosen in high vibration applications.
Even in my race car, I have no bolts safety wired. My Harley doesn't have any and it vibrates. Loctite in an automobile is more than enough unless a rule specifies it.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Fatdog2
Feb 13, 2015 08:19 PM
Jan 23, 2015 01:13 PM
