Proper way to Power Shift
Old May 12, 2003 | 09:47 PM
  #16
tainted's Avatar
what are you going to go with?
Old May 12, 2003 | 11:08 PM
  #17
Koors96Z's Avatar
Probably the street twin, so by the time my engine is finished next summer I will have a clutch that can handle the power. I don't want to buy a cheap one and have to replace it next year, so I'll just spend the money and do it right the first time.
and to answer your original post, i keep the gas pedal all the way down and push the clutch in and shift as fast as possible.
Old May 13, 2003 | 10:06 PM
  #18
sb427f-car's Avatar
If you're that worried about synchros, call up jerico and see if they will swap in some good ol straight cuts. Then, powershift without lifting and without the clutch, no worries @ all.
Old May 13, 2003 | 11:37 PM
  #19
tainted's Avatar
What are straight cuts? :>
Old May 14, 2003 | 09:14 AM
  #20
rncotton's Avatar
At the track last night, I tried it both ways.
Out of 6 passes, I powershifted 3 and lifted off the gas for 3. Every run was 13.4xx
Old May 14, 2003 | 12:40 PM
  #21
sb427f-car's Avatar
Straight cuts, what also maybe known as a dog box, literally uses a straight cut gear. Instead of using synchros, through them out, the gears look like something you would see in a truck tranny or reduction gears for an airplane prop. Instead of having a twist to the teeth (like a helical (sp) cut gear) they are totally perpendicular to the tangent of the circle they sit on. In other words if you were to look @ a gear from the side, you would see the teeth coming off in perfect lines, where as a normal gearbox with helical cuts and synchros would start to curve around the gear. Hope that kinda helps, I might have confused you more. Anyways, that's what all the NASCAR tranny's are, they don't need to use the clutch to shift up or down, just mash the gas, lift ever so slightly when you pull gears and on the downshifts, left foot on the break, right on the gas, match your gear speeds and jam gears.
Only problem with a straight cut gear box is that they are noise as hell.
Old May 14, 2003 | 02:38 PM
  #22
RADLT1MO's Avatar
I've never NOT powershifted at the track. Never broken a tranny and my car was running consistent 10 teens for a whole season!! If you are not experiencing any et gains by powershifting, you shift too slow. Practice, practice, practice. I've had tons of people come by where I was pitting and couldn't believe my car was a stick. Driver preference I guess.
Old May 14, 2003 | 06:08 PM
  #23
sb427f-car's Avatar
Love that sig man. to CID
Old May 15, 2003 | 07:45 PM
  #24
MustangEater82's Avatar
I powershift... attributes alot to my decent times for a 3.4L with so few mods(beating heads/cam guys).
but....
4th clutch
2nd driveshaft
2nd tranny mount
2nd rebuild(as in was rebuilt then broke again, and rebuilt)
2nd rear end
2nd torque arm(yes I broke a torque arm with a 3.4L)
My car is a 94 with 126,000 miles on it.
It does help, it is bad for the car, and the primary problems with my tranny was a stripped gear, and worn synchros all over the car.
Old May 19, 2003 | 12:46 PM
  #25
sb427f-car's Avatar
That's why jerico trannies don't run synchros and use the stronger straight cut gears, you can flatshift / powershift, w/ or w/o clutch, and have tons of power and not truely worry about breaking tranny parts. Then again, there are always the planetary gear setups of Lenco and Liberty Gear. Clutchless trannies =
Old May 20, 2003 | 12:46 AM
  #26
phil94-T/A's Avatar
Is it advised to powershift when on the juice...or does the chance of things going boom increase?
PHIL
Old May 20, 2003 | 09:21 AM
  #27
sb427f-car's Avatar
PHIL
You should be fine, as long as you don't miss a shift. Bouncing a motor off the limiter under boost or N2O is most definately not a good thing. If you think you can rip the gears quick enough and not miss the shift, then powershift it.
Old May 20, 2003 | 11:30 PM
  #28
phil94-T/A's Avatar
Thanks for the info..........I'm going to be new to N20 and just needed to know if it was safe to power shift........
F'n1996Z28SS
Aug 23, 2023 11:19 PM
jb4xx
Feb 2, 2015 10:00 PM
XtremeLt1
Sep 13, 2002 08:50 PM
