Ply mix,oxygen sensors
Old Oct 13, 2003 | 03:42 PM
streetbad's Avatar
Is running bias ply (Goodyear Frontrunners) and rear radials (BFG) NHRA legal? Is i t legal for Radial tire class? Is it Safe ?? Also does runnning oxygen sensors with open headers work? I can put collector extensions on (any length) Thank You !!! -Tim
Old Oct 20, 2003 | 08:52 PM
streetbad's Avatar
going saturday,what should I do ?
Old Oct 20, 2003 | 09:53 PM
RacinLT1's Avatar
yes the tire combo is legal.
as far as the )2's you can run them with open headers,dunno if extensions would help or not.
Old Oct 21, 2003 | 03:17 PM
Camride's Avatar
I'm not sure how well running open headers and an o2 snesor would work. You can try it, but it might give you some wierd readings if it's too close to the end of the collector. If it does give wierd readings/make the car run crappy I would recommend just getting some o2 sims.
Aug 24, 2015 06:41 AM
pimpen1024
Aug 19, 2015 08:36 PM
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
350350
14
Aug 11, 2015 12:03 PM
Noct
Jul 14, 2015 01:18 AM
