Please explain these slips
Old Apr 5, 2007 | 11:18 PM
350pride's Avatar
Time slip one: Me Time slip two: Me
reaction time: 0.0615 reaction time: 0.0406
60': 1.9652 60': 2.0982
330': 5.4775 330': 4.6568
1/8th: 8.3874 1/8th: 8.5686
MPH: 84.76 MPH: 85.32
Without stall With 3600 stall
I realize that I was spinning off the line, but is what Im seeing true? Im I spinning once I get past the 330' mark? or is it something else?
Old Apr 6, 2007 | 07:35 AM
Ken95Z28's Avatar
What type of converter?
Looks like the converter is not setup to your motor.
Old Apr 6, 2007 | 08:59 AM
AL SS590 M6's Avatar
Moderator
What's your rear gear?
Maybe the addition of the converter is making the trans slip in second gear. Or maybe it is blowing the tires off at the 1-2 gear change.
Or maybe with that big of a stall it's going from 1st right into 3rd gear limp home mode. Anything over a 3000 stall can cause problems of this sort unless it's been tuned for.
Old Apr 6, 2007 | 01:32 PM
TedH's Avatar
You may have too tall of a stall for the combo.... I run a 3600 stall but have a stroker. I would have probably selected somewhere around 3000-3200 for your setup. But anyway, the slips do not make sense.... Your trans could be slipping.... Did you use synthetic when you installed the new converter? If so it may be too slippery for the transmission.... Just a thought... I've been wrong before...
Old Apr 7, 2007 | 01:05 AM
Z-RATED94's Avatar
Whos converter are you using? What rearend gear ratio?
Old Apr 7, 2007 | 12:07 PM
350pride's Avatar
Im using a TCI torque converter 3600. Got it used. I as far as slipping goes, Im feeling go smoothly into every gear, and as far as going from 1 to 3, I felt it hit every gear.
So I guess I need to get the car tuned for the converter???
The reason I got a 3600 stall was that my friend has a supercharged + cammed v6 camaro. He was putting down like 297 hp and 285 tq and he had a 3500 stall, and he was cutting like 1.8xx 60' and running low 8's.
So I figured if I got a stall similar to his I could cut similar 60 and run in the 7's.
Thanks for the responses...please keep them coming.
Old Apr 7, 2007 | 01:34 PM
Jared 3870's Avatar
That may be true for him, but the type of stall you use depends on your rear gear and where your motor makes its power. I gaurantee his blower v6 makes power far differently than your mildly cammed v8.
Go to the drivetrain section and read the sticky about stall speed.
Old Apr 8, 2007 | 01:25 AM
Z-RATED94's Avatar
Ok, start saving, and replace that TCI with a real converter. Do a search, you get what you pay for. Make sure you use a trans cooler too, if you don't already have one.
Old Apr 8, 2007 | 10:36 PM
350pride's Avatar
I have 3.23 gears, but I have a set of 373 that I can put in there. Do you think this would help???
Old Apr 8, 2007 | 11:05 PM
Z-RATED94's Avatar
Sure would, especailly with a quality 3600 converter. As long as you have some sticky tires that are up to it.
IndyZman
Oct 22, 2015 02:17 PM
ZXXVIII
Sep 1, 2015 10:13 PM
Nickster 7
Aug 27, 2015 10:12 PM
350350
14
Aug 11, 2015 12:03 PM
Jul 17, 2015 02:47 PM
