Pinnion angle
Old Nov 13, 2006 | 05:20 PM
neil350's Avatar
Pinnion angle
Is the importance just in the way the car launches, I never checked mine after I did the track link, same adjustment as the car it came off of, on a bolt on car with a 150 shot, how big of a factor will it play?
Old Nov 14, 2006 | 08:28 AM
Z-RATED94's Avatar
What's a track link, is it a torque arm, control arm? Is it adjustable? I need some more info before I tell you how much I can't help you.
Old Nov 14, 2006 | 10:34 AM
Jerm93z28's Avatar
Pinion angle in itself has nothing to do with the way the car launches.
Old Nov 14, 2006 | 11:01 AM
Z-RATED94's Avatar
I may be wrong but if a lowered car or (any other car for that matter) has a positive 2 degree pinion angle and by changing to a negative 2 degrees can plant the tires better you might not be correct. Then again maybe this only works on my car?
Old Nov 14, 2006 | 06:06 PM
Jerm93z28's Avatar
anything is possible i guess... but i dont see how.
the only way to change how the car hooks up is by adjusting the front torque arm mount location, or the lower control arm positions. this is not including the front suspension adjustments, of course.....
anyways, the whole purpose for running -2 degrees of pinion angle is so that when your under full accelleration, all the deflection in the suspension components and bushings will bring the pinion up to zero pinion angle. this will produce the least amount of drag.
Old Nov 16, 2006 | 02:25 PM
383Z4ME's Avatar
I think that running more negative pinion angle moves your instant center and this increases the amount of weight shift at launch. I ran mine at -4 when racing and around 0 to -1 when not racing. Do a little research on instant center.
Old Nov 16, 2006 | 03:08 PM
CamaroSS30thAnn's Avatar
pinion angle will help control some wheel hop when launching
sor far most ppl say that:
auto -2 degrees is good
manual -3 is good
i can c if ur angle is off by alot , u may eat through alot of pinion seals
Old Nov 16, 2006 | 04:18 PM
Jerm93z28's Avatar
so how is pinion angle going to change your instant center?
Bobczar
Oct 23, 2015 11:22 AM
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
Aug 7, 2015 01:26 PM
CARiD
Exhaust System
Aug 3, 2015 05:10 AM
LT1 1980 malibu
Advanced Tech
Sep 13, 2002 08:21 AM
