people with lift off hoods, help me out
Old Jun 16, 2007 | 05:59 PM
mdacton's Avatar
anyone running a lift off on a 4th gen?.....I have installed many on other cars but all of them had metal fenders.
Has anyone used quarter turn brakets and just riveted them to the fenders? Just wanted to ask, the stuff seems pretty weak
Old Jun 16, 2007 | 08:34 PM
jasonisdn's Avatar
i bought some locking hood pins for the front and normal hood pins for the rear. make sure to attach a few photos when your done. my hood is still being made by vfn (i think that is who i ordered it from).
Old Jun 16, 2007 | 09:55 PM
mdacton's Avatar
I will post pics.
I went with a glasstek 4" probly do 4 1/4 turns on each side and 4 across the front
Old Jun 18, 2007 | 08:46 AM
T/A lt1's Avatar
I am using the 4" Glasstek and used the 1/4 turns like you. Here are some pics of mine when finished. http://www.gmhightechperformance.com.../photo_02.html
http://www.gmhightechperformance.com.../photo_01.html
The only thing I would do differently is put 4 on each side and mount them using a metal rail all the down each side. Later Clint
Old Jun 18, 2007 | 11:39 AM
Z28SORR's Avatar
On my 84, which has plastic fenders, I used a row of Dzus fasteners down both sides(5 each) and pins(2) in the front. I also used individual "L" brackets riveted into the fenders, for each Dzus. I have had no problems after years of use. There have been no signs of pull through or cracking. I did however reinforce the edges of the hood, not the fenders, with extra fiber glass.
Old Jun 18, 2007 | 12:23 PM
mdacton's Avatar
i think im going to do 4 on each side and reiforce everything like you said.......
I don't want my hood to blow off, have seen alot of them do it
Old Oct 10, 2007 | 12:38 AM
10sec LT1's Avatar
any info on how to reinfoce or brace theese hoods to make them more sturdy?
Old Oct 11, 2007 | 10:14 AM
Z28SORR's Avatar
The reason for buying this type of hood(race hood) is for the light weight. If you add a lot of heavy reinforcement to it you negate the reason for buying it in the first place.
If you want or need a sturdier hood, then get a street hood. It's still lighter and you can get the design you like.
Are you having a specific problem??
Old Oct 11, 2007 | 06:33 PM
mdacton's Avatar
This would be good to know if he does.
My hood had a lot of flex in the rear so I ended up making 2 tabs that come of the firewall out of 16ga and have a dzus on each side of the cowl in the rear. Made the hood alot more sturdy
Old Oct 12, 2007 | 10:57 PM
10sec LT1's Avatar
yeah i have the same problem thanks for your help i'll try that.
kandied91z
Jan 23, 2015 11:14 AM
CARiD
Jan 14, 2015 04:00 AM
Z28Wilson
Aug 1, 2002 04:27 PM
Antz97ZNJ
48
Jun 20, 2002 06:09 PM
