Paging all Michigan drag racers and close by!
Old Jul 23, 2002 | 09:29 PM
firstgen's Avatar
Post Paging all Michigan drag racers and close by!
Milan Dragway!
The Eastern Michigan Camaro club has the track rented this Monday July 29th. Gates open at 6:30pm and we run from 7pm thru 10pm.
Each car running will cost $30 or less (Depending on turnout) and spectators are free.
Last few times we had like 25 or less cars, and there is no wait to run so you can run as many runs as you want. It's a fun time plus great for tuning and testing.
I'm inviting you all you're all Welcome no matter what you drive.
Hope to see you all there!
1967 Camaro SS - 468 BBC modified
1967 Camaro RS - 327 stock
1969 Camaro Z/28 - DZ302 stock
2000 Ducati 996
Member of the Eastern Michigan Camaro Club
Old Jul 23, 2002 | 10:35 PM
taner's Avatar
From: Windsor, Canada: Home of the FASTEST LT1 & LS1 6 spds :)
Post
will they prep the track?
normally the traction is not very good there?
thanks
taner
Old Jul 24, 2002 | 12:23 AM
firstgen's Avatar
Talking
I'm sure we can get them to prep it. I was spinning off the line last time out but I think it was more of a weight transfer to the rear problem then anything. I'll soon know this time out. New springs and shocks this time around and bigger fuel line with new pump.
2000 Ducati 996
Old Jul 24, 2002 | 08:41 AM
jp2002ls1's Avatar
Post
Sweet, I will definately try to be there in my 2002 Z28, I usually go on Wednesdays or Fridays and it is always busy there, usually only get 5 runs the whole time they are open on Wednesdays. It also usually costs $20 to race so $30 ain't bad as long as you can get a lot of runs. The track does suck for traction though, I can never get my car to hook up there. Hope to see you guys there!
Old Jul 26, 2002 | 01:58 PM
97 6SPEED Z's Avatar
Question
I know you mentioned that spectators are free, so if I can't get the Z ready to test and tune by Monday, can I just drive up and watch for free or are they charging every CAR that comes in?
'97 LT1, MN6, !CAGS, Throttle Body By Pass, 160F Thermostat, Pro 5.0 shifter, BMR Shock Tower Brace, BMR Sub Frame Connectors, 3" Super Turbo Cat Back, Moroso CAI, and SLP Airfoil, LT4 KM, Pacesetter shorty headers, Nitto 315/35/17 drag radials, ASP 34% underdrive crank pulley, Comp Cams XE 230/236 cam and 1.6 to 1 ratio roller rockers, OBD1 conversion PCM, de-screened MAF. Best 1/4 mile pass,(so far),13.060 @ 109.53 with 2.287 60ft time.
Old Jul 26, 2002 | 02:27 PM
firstgen's Avatar
Post
You can drive up and watch for free.
2000 Ducati 996
Old Jul 29, 2002 | 08:06 PM
taner's Avatar
Post
is there a rain date?
thanks
Old Jul 30, 2002 | 04:11 AM
firstgen's Avatar
Talking
I'll post it as soon as I find out.
2000 Ducati 996
Old Aug 5, 2002 | 02:41 PM
Post
Was there ever a rain date set for this? Thanks
MikeWhitener
Aug 2, 2015 06:17 PM
94Form
Jul 17, 2015 10:56 PM
Boss002
Jul 9, 2015 03:33 PM
NewsBot
Apr 14, 2015 04:00 PM
