Opinons on these flow numbers.
Old Jan 29, 2004 | 01:22 PM
rje's Avatar
rje
I just had my heads serviced and flowed. Here are the numbers, what do ya'll think?
int. exh.
.100 81.1 65.9
.200 140.5 127.7
.300 194.7 163.1
.400 238.5 199.8
.500 263.1 220.5
.550 267.2 224.2
.600 269.6 227.9
.650 263.1 235.3
Randy
Old Jan 29, 2004 | 06:44 PM
red's Avatar
red
Flow number will not tell the whole story. Flow number are relative to what RPM range the motor will operate in, what cam is selected, CI and other items.
If you are looking for an opinion on what can be achieved the your numbers are OK.
Old Jan 29, 2004 | 08:51 PM
rje's Avatar
rje
I was just asking to be curious, since everybodys been talking about how good Lloyd Ellioits heads are and mine beat his by some 30 cfm on the exh and there four years old. As for my setup, I'll be running my 355, the same one that I ran the times in my sig and I just found out that I ran those times with a slightly bent valve and several badly worn valve guides.
Randy
Old Jan 29, 2004 | 09:15 PM
Stephen 87 IROC's Avatar
Providing you have a camshaft that supports those lift numbers, the heads have potential to support around 550hp. That's also assuming those flow numbers are at 28" of water.
Old Jan 30, 2004 | 01:03 AM
97bowtie's Avatar
If those are LT1 castings, those exhaust numbers look bogus. How were the heads flowed? With a pipe? What flow bench? The intake numbers look pretty decent, but as already stated flow numbers don't tell the whole story.
Old Jan 30, 2004 | 05:58 AM
Raptor1's Avatar
Randy, what heads do you have (LT1, LT4) and who ported them?
Old Jan 30, 2004 | 07:49 AM
rje's Avatar
rje
Hi Mark, how are you doing? I hope you had a good holiday.
The heads are LT1's, the same heads I've had for almost four years. I just had them flowed and seviced by charles at Headsup performance, and they were flowed at 28'' of water,the port work was done by Bob and myself.
Randy
Old Jan 30, 2004 | 08:14 AM
rskrause's Avatar
Moderator
Those are the best exhaust flow numbers I can recall seeing for an LTx casting. Are you sure they are accurate?
Rich Krause
Old Jan 30, 2004 | 08:41 AM
rje's Avatar
rje
Well I can't be 100% sure, but that is what the floe sheet read, and I trust the man who flowed them. It will all come out in the wash. When I get my new cam in and it's a dog we'll know the numbers are bogus, but if it flys we know there right.
Randy
Old Jan 30, 2004 | 11:56 AM
rje's Avatar
rje
I just got off the phone with the guy who flowed my heads, and he said that he flowed the exh with a pipe. He said just to just reduce the flow numbers by 10-12 cfm on the exh and that would be what they would be without the pipe.
Randy
Old Jan 30, 2004 | 12:15 PM
rskrause's Avatar
Moderator
Randy
Still very good, but makes more sense now. Thanks.
Rich Krause
Old Jan 30, 2004 | 12:54 PM
allmotorta's Avatar
Old Jan 30, 2004 | 12:59 PM
Raptor1's Avatar
Randy
Linda and I had a great holiday! Thanks for asking
Those are some great flow numbers, especially assuming you guys did the porting by the guess-as-you-go method (unless Bob has a flow bench hiding in the corner somewhere that he's not telling anyone about )
It will be interesting to see how it runs this year!
Old Jan 30, 2004 | 01:44 PM
WS Sick's Avatar
Thos flow really well, since the exhaust flows so well I wonder if a single pattern cam would work with those?
Formula Steve
Sep 19, 2023 08:31 AM
Daluchman1974
Sep 11, 2015 06:12 AM
Slayer
Aug 17, 2015 03:55 PM
alphaauto
Jul 26, 2015 04:40 PM
camaro02DK
Jul 5, 2015 09:24 AM
