old school
old school
i know theres a ton of threads here about "how to i drag better" etc. but, i was wondering if theres any techniques that i should use for my Z. I've got an 81 z28 with a 4spd. hurst shifter and a 350hp 355. Its got the stock lmtd slp rear in right now but i've got a posi to put in at some point. Will the posi help alot? also my back tires are 295 50 r15's.
Re: old school
Originally Posted by JakeRobb
Posi and limited slip are two names for the same thing.
Posi will definately help your times, i don't no how much though.
Re: old school
Originally Posted by x-40oz-x
Posi both tires spin, limited slip only one tire spins(usually the right side) and the other sits there.
Positraction is to limited slip as Kleenex is to facial tissue.
Rich
Re: old school
Q-tip, Skidoo, Kleenex, Aspirin, Posi are some of many brand names that get used as a generic name.
GM calls it a Posi, Ford calls it a Traction Loc, I can't remember what Mopar called theirs.
If the GM diff uses clutches, it's a posi plain and simple. There's also something called a Gov Lock. The diff is an open diff but locks up when one wheel starts to spin, it has a toothed gear and latches which grab the teeth. That's the best description I can give. You can't manually tell if the diff is a Gov Lock or an open diff without driving it or taking the rear cover off to inspect it. Technically the Gov Lock can be considered a limited slip but a posi although it's a limited slip, is simply called a posi.
My car has a spool
My car has a spool
Re: old school
Posi will make a big improvement in your 60' times over an open differential, especially with a sticky set of tires and a good suspension setup.
Do you have any experience launching with another setup? What techniques are you familiar with, and what has worked for you in the past? That information should help us tell you how to adapt to the new setup.
Re: old school
Okay.
Launching any reasonably high-horsepower car at the dragstrip is a matter of experimenting and finding what works best. Every car is different.
I'm assuming you're running on street tires.
For your first launch, get staged and bring the revs up to 1500 or so, and when you see the last yellow light on the tree, let the clutch up smoothly and fairly quickly and get into the gas. This should get you a decent reaction time, but you'll want to experiment to minimize it.
After your run, look at your timeslip. On street tires, 1.9-2.0 is a pretty good 60' to shoot for.
As you make more runs, experiment with the RPM, the rate at which you let the clutch out, and the rate at which you put the gas pedal down, and work in whatever direction gets you better 60' times.
Most of all, have fun!
Re: old school
sweet, thanks for the help-i've got aftermarket tires on, i'm not sure how soft but the rears are definately pretty wide. i've got a cement pad at my house thats gotta be at least 100' long so i might try practicing on that before going to a track. only problem is its kida rough in some spots and not great for the tires.
Re: old school
A prepped drag strip is going to be pretty different than your clean concrete, rough or not. It's fine to practice, but you can probably expect to have a bit more traction at the strip.
Oh yeah, and don't do a burnout in the burnout box on street tires. If there's room to drive around it so that your tires stay dry, do that.
Re: old school
Rich
Henson071
Dec 30, 2015 09:55 PM
RX Speed Works
Jul 24, 2015 02:25 PM
