No 12's (yet) But New PB
Old Apr 9, 2011 | 09:54 PM
transamtom's Avatar
Went to the track today and had a good time.
They had a few timing problems, no 1/8th on one slip no MPH on another.
The car ran real well but I couldn't get a decent 60 ft time even with the DR's.
It was also the first time its been WOT since the LT install and tune.
First Run 11:06am RL
60ft 2.009 1/8 N/A 13.209 at 106.33mph
Second Run 11:15 LL
60 ft 2.058 1/8 8.544 at 85.21mph 1/4 13.183 at 106.35mph
Third Run 11:29 LL
60ft 2.055 1/8 8.546 at 85.23mph 1/4 13.175 at 106.96mph
Fourth Run 11:37 RL
60ft 2.015 1/8 8.537 at 85.51 mph 1/4 13.161 at 106.33
Fifth Run 11:43 LL (Best Run)
60 ft 2.066 1/8 8.534 at 85.57 1/4 13.141 at 107.83
Sixth Run 12.21pm RL
60ft 2.013 1/8 8.579 at 84.96 1/4 13.231 MPH N/A
Too many FWD cars driving right through the water box :x
A lot of peoples 60fts were off as they were spinning.
Old Apr 9, 2011 | 11:43 PM
Bersaglieri's Avatar
Re: No 12's (yet) But New PB
What's your mods and what kind of radials and suspension work do you have?
-Dustin-
Old Apr 10, 2011 | 01:11 AM
transamtom's Avatar
1)SLP LID,OBX Long Tube Headers,Tuned by Frost.
2)Hoosier DR's.
3)Stock suspension.
Old Apr 10, 2011 | 11:23 AM
If you're looking for 12's maybe get that 60' down by adding some suspension? No sure what your ultimate goal is. Those Hoosier DR's should hook up even with stock stuff on a good day.
-Dustin-
Old Apr 10, 2011 | 03:37 PM
transamtom's Avatar
-Dustin-
Lots of cars had problems hooking,guys on street tires were in the 2.2- 2.4 zone.
Poor track prep and FWD cars pulling water to the line.
Old Apr 10, 2011 | 07:36 PM
I already read that, I'm just saying either some suspension and/or a good track day may get you into the 12's.
-Dustin-
Old Apr 14, 2011 | 11:27 PM
Gtpguy's Avatar
Lower control arm relocator brackets work wonders and are very cheap. I put them on my old Formula and it took alot of fun out of daily driving with the added traction.
Old Apr 18, 2011 | 11:14 AM
Mystery Bird's Avatar
Are you getting the tires hot enough? running the right pressure?
Old Apr 18, 2011 | 06:13 PM
transamtom's Avatar
Yes I tried long burnouts short burnouts.
Started at 23psi and was at 18psi for the 4th 5th and 6th runs.
I am going to try again this weekend.
Old Apr 21, 2011 | 06:24 AM
AL SS590 M6's Avatar
Moderator
-Dustin-
Yeah I run Hoosier DRs on my race car and pull 1.4-5 sixties with my fronts in the air every pass. I have never spun them.
Medium burnout, 21 psi.
Old Apr 22, 2011 | 06:35 PM
transamtom's Avatar
Thanks for the info.
I will be getting a Yank 3600 stall,that should help the 60ft a bit.
Old Apr 25, 2011 | 05:03 PM
Rising Phoenix's Avatar
Bingo! That's gonna be the key, you will hit 12's all day long with that.
Old Apr 26, 2011 | 10:12 PM
84zed's Avatar
With that kind of mph and a 3600 stall you should hit low to mid 12`s if you can
get it to hook.
Old May 24, 2011 | 05:04 PM
Black_Z's Avatar
I know what you mean. On a stock internal, stock program, stock rocker arms even, I went 13.003 @ 106.64mph. I couldn't get a twelve second timeslip no matter what. I gave up the quest on stock internals with stock suspension, built a 383 stroker with AI heads and the works. Got a 12 second pass under my belt, now chasing the 11's. I am beginning to think this will never end
Old May 24, 2011 | 06:56 PM
transamtom's Avatar
It doesn't until you run out of money
