Nitto DR's...Got a Question
Old Jan 13, 2004 | 05:20 PM
dj haf's Avatar
what tire psi should i leave it at while driving around? and at the track? i heard 15 psi would be fine for both so that they wear evenly... anything over 20 would make them wear out in the middle... am i correct on this?
Old Jan 13, 2004 | 05:58 PM
steve10358's Avatar
3rd Gen Tech Moderator
I am going to move this to the drag racing forum.
Old Jan 14, 2004 | 11:10 PM
Gold Z's Avatar
24 psi works best for me on the street.
Old Jan 15, 2004 | 12:25 AM
94camarof1's Avatar
Around 25 psi
Old Jan 15, 2004 | 09:45 AM
MattysTA's Avatar
20psi, im about to put on my third set now and the first time i ran 30psi they wore out in the middle quick, the second time i went to 20psi and they wore perfectly....
Old Jan 15, 2004 | 10:31 AM
NoFear95's Avatar
I run 32 on the street and 22 at the track. At 22 pounds they hook hard. But at 22 pounds they feel alittle shakey on the street.
Old Jan 16, 2004 | 09:18 PM
Steve in Seattle's Avatar
After two sets of these, and 40,000 miles between them I can honestly tell you that 30 psi was too much for me to see even tire wear.
If you're limping around stop and go traffic anything under their 45psi max is fine. But for highway driving, or any summer driving that will get them warm, keep'em to 25.
If you highway drive a lot (I commute 70 miles/day), plan on 25 psi. At the track I found 24 to 23 was about the useful limit. This will obviously vary based on the weight of your car, the speeds you drive, etc... So make sure to check the wear pattern at least monthly and adjust as nessesary (I used to make a note of glacing at them before heading to work in the morning).
Old Jan 18, 2004 | 12:11 AM
offaxis's Avatar
On the street I run them at 26 psi . When i am going to race ( on the street or the track ) I put them at 18 psi . I do a nice long burnout and average 1.60-1.65 60 fts on stock suspension
Hope that helps
Jeremy
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
sloppytot
Feb 25, 2015 08:30 PM
Jason Short
Jan 19, 2015 06:33 PM
96z
Aug 2, 2002 09:00 PM
