New Lt1 Stockhead best
Old Dec 9, 2003 | 06:02 PM
  #31
Frank95z's Avatar
Maybe Comp cams will send me a new cam to try for Christmas. Hint Hint Frank95z
Old Dec 10, 2003 | 01:55 PM
  #32
Fast Caddie's Avatar
Sweet, are you going to run it with the stock heads first or are you going to do both H&C at the same time?
Old Dec 10, 2003 | 11:13 PM
  #33
Frank95z's Avatar
No fast caddy I don't want to confuse you. You said I wonder what Franks car would run with a 305 or 306 cam. And my reply is maybe Comp Cams will send me one for Christmas. If and when I change cams I'm sticking to stock heads. Now if any cam company would like to send me one to try i'm open Frank95z
Old Dec 16, 2003 | 12:50 AM
  #34
faded93bird's Avatar
Why change something that works so well ? I mean the car is proof that bigger is not always better.
was wondering if you would like to possibly share your weight loss plan?
Old Dec 16, 2003 | 01:20 AM
  #35
LT1ponykilla's Avatar
Thats sweet man.
Old Dec 24, 2003 | 02:17 AM
  #36
atljar's Avatar
You need a 847 cam. If i was hooking like that and wasnt full weight, oh wow I dont see why 10s wouldnt be in sight with stock heads.
Old Dec 25, 2003 | 08:28 AM
  #37
funina91ss's Avatar
Frank how are you leaving the line in that? If I rember right you took out the A/C too right?
Sweet times I need to gut mine a little but I will not let the A/C go. 1 more question do you have a rollbar? If not your cheating
Sean
Old Dec 26, 2003 | 10:16 AM
  #38
Frank95z's Avatar
Funina91ss I did remove ac but not heater or defroster. I leave the starting line 2 different ways. When I bracket race I stall up to 1500. That method gives me the best reaction times. To run fast i leave off of dead idle. The suspension seems to work better this way with no preload. I do have a rollbar,5 point harness,driveshaft loop,steel stems,firejacket and Snell 95 helmet. So I am legal Frank95z
Old Dec 26, 2003 | 10:29 AM
  #39
funina91ss's Avatar
I had you mistaken for someone else sorry Nice weight in #'s with a Bar in it Your car must hold a few records mainly the 60ft for a stock heads and bottemend car with no poweradders. But that might have alot do with your cam being smaller it pulls harder down low I bet. either way You have a great combo that works. My hats off to you.
Old Dec 26, 2003 | 11:14 AM
  #40
Frank95z's Avatar
Thanks I just weighted my car today. I found a few pounds it weighed 3165 with me in it. I weigh about 175#. The car also has a 12bolt rearend with HD posi. Frank95z
Old Dec 26, 2003 | 06:15 PM
  #41
SAR2K's Avatar
Talking
Wow Frank, that titanium block & PVC roll cage really helped out!!!
Old Dec 26, 2003 | 07:59 PM
  #42
Frank95z's Avatar
Thanks Steve for loaning me your 3 in. holesaw Frank95z
Old Dec 27, 2003 | 05:28 AM
  #43
Victory Racing's Avatar
By stock heads are we meaning LT1 heads that have been ported and re-valved/jobbed , or are we saying completely un-touched LT1 heads the way they came from the general??
Old Dec 27, 2003 | 10:52 AM
  #44
atljar's Avatar
They mean untocuhed heads, no valve job, no milling, no porting, acid porting, polishing etc.
Old Dec 27, 2003 | 10:11 PM
  #45
Frank95z's Avatar
What atljar said unported,no milling,no polishing,no acid, no epoxy,but these heads that I have now have a new stock angle valve job. Frank95z
