Need some input
Old Apr 8, 2004 | 04:02 PM
bad93z's Avatar
Need some input
Haven't had my 95 to the track yet, and I'm thinking about going this Tuesday. The car has 98,000 miles on it, stock clutch, stock 3.42 gears.
Mods are :
K&N Coldair intake
SLP airfoil
Hooker Ceramic Coated Longtubes
!EGR
!AIR
Throttlebody Bypass
Descreened MAF sensor
LT-4 Knock Module
Jet Skipshift eliminator
Flowmaster 80 series muffler
!Catalytic Converter
Cutout
Lakewood lower control arms
BFG Comp TA Drag radials on salad shooters
I think I'll leave the BFG's at home, as I really can't afford to break my rear.
What RPM do you guys think I should launch at?
What kinda times can I expect to see?
thanks alot
Clint
Old Apr 8, 2004 | 04:31 PM
Kreinmc's Avatar
Most likely you are going to be running mid to low 13's at anywhere from 104-108 with those mods. Bring the BFG's with you, i highly doubt you will break your gears on a DR with stock gears and a stock clutch. Your clutch will slip well before you break your rearend. It will be pointless racing on street tires if your car is running strong.
Old Apr 8, 2004 | 05:08 PM
BiGGinZ's Avatar
I also agree about the DR's.
Old Apr 9, 2004 | 08:15 PM
bad93z's Avatar
With the drag radials how should I launch?
Nayr
Mar 3, 2023 08:34 PM
Ericksd
Jan 20, 2016 06:07 PM
marlar98
Oct 21, 2015 02:02 PM
drt
Sep 27, 2015 04:39 PM
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
