Is my car slow?
Old Aug 18, 2006 | 01:53 AM
93Phoenix's Avatar
Is my car slow?
My car has mods in the sig.
This was my first time to track ever. My rear tires are bald as well, okay enough excuses.
First run
60' 2.495
1/8 10.17 @ 74.20
1/4 15.36 @ 95.98
Second run
60' 2.481
1/8 9.756 @ 76.68
1/4 14.86 @ 97.10
Third run
60' 2.304
1/8 9.482 @ 76.62
1/4 14.58 @ 96.97
Elevation is 1100 ft and it was about 80 degrees slightly humid.
Old Aug 18, 2006 | 02:01 AM
Daniel6718's Avatar
Re: Is my car slow?
nope..track times i relaly dont even count unless you have a sub 1.8 60'
oterwise it makes you car seem slow
Old Aug 18, 2006 | 02:18 AM
93Phoenix's Avatar
Re: Is my car slow?
Do I need some DR's then?
95custom's Avatar
Re: Is my car slow?
how do you get your 60 ft. times so low? is it the bald tires? .. car isnt slow, the 60s are terrible and the mph is where it should be.
Old Aug 18, 2006 | 02:20 AM
93Phoenix's Avatar
Re: Is my car slow?
First time I missed 2nd, yea... powershifting and didn't get it in.
Second time I got sideways off the line, doh!!
Third time I was conservative.
Old Aug 18, 2006 | 04:51 AM
jonathan_abilene's Avatar
Re: Is my car slow?
we dont want to hurt your feelings
Old Aug 18, 2006 | 08:50 AM
AL SS590 M6's Avatar
Moderator
Re: Is my car slow?
Put a better tire on it and take it back out.
Old Aug 18, 2006 | 12:07 PM
93Phoenix's Avatar
Re: Is my car slow?
As in DR's? Are bald street tires worse then if they had tread on them?
Old Aug 18, 2006 | 01:43 PM
93redBirdMan's Avatar
Re: Is my car slow?
of course bald tires are a LOT worse than tires with tread. Get some drag radials in the rear and you'll hit 2.0 60' easily. Then you'd be at a 14.0 or 14.1 right where you should be...
Old Aug 18, 2006 | 07:35 PM
frankthetank078's Avatar
Re: Is my car slow?
your engine also has 125k on it so its probably loosing alittle horsepower at that so overall i think those are good times
Old Aug 18, 2006 | 10:40 PM
93turbo5oh's Avatar
Re: Is my car slow?
get the drag radials, the best your gonna get out of a 3.42-3.23 with a 6 speed NA stock motor is a 2.0 60'. when my car had the original goodyears on it i think i went a 9.20@78 or 79 1/8 with a 2.20 60'. the car was bone stock with 51K miles on it. i put the cai, exhaust, tuning and nittos and a best of 8.61@84 with a 2.08 60'. that was slidin the stock clutch. traction was marginal at best. that was when it was 40* outside though.
track prep and tire are the key. i normally run at a track that the prep sucks, last night i ran my best 60' ever without even doing a burnout at a track that has good prep. so i cant wait til it gets cold again so i can go back and maybe score some high 8.40s and get the car back to running 83-84mph with a tuneup and cold air.
Old Aug 19, 2006 | 01:12 AM
93Phoenix's Avatar
Re: Is my car slow?
I forgot to drop some rear tire pressure as well..
How about removing the front swaybar?
Old Aug 20, 2006 | 05:19 AM
Moderator
Re: Is my car slow?
That will help by letting the weight transfer to the rear better.
Jazsun
Dec 29, 2014 12:14 PM
USAirman93
Nov 24, 2014 03:37 PM
cryptopsy
Aug 19, 2002 12:19 PM
Matt-01-SS
Aug 2, 2002 04:05 PM
sc93
Jul 26, 2002 02:02 PM
