Mickey Thompson ET Street Radials
Old Mar 19, 2005 | 12:09 AM
  #31
old93z's Avatar
Re: Mickey Thompson ET Street Radials
frmula the main thing limiting the 60' with et streets would be stock stall. It will most likely dead hook.
best 60' i got with the stock stall and et streets was a 1.82 on the way to 11.9 at 117 (n20) and about a 1.95 on motor~13.4@102.
Old Mar 19, 2005 | 12:45 AM
  #32
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
yeah i was anticipating a dead hook with them...
my cars sick so now i don't even know if im gonna get to try em out this weekend... i left the line at 12-1300 on street tires got a 2.05 60' and landed 13.33 at 104.78 full tank of gas, tire, jack, and about 30 lbs worth of crap in my car... im gonna run it at 1/4 tank of fuel or less... and remove all weight i can then leave it at 1500 and try to dent the floorboard.... its also gonna be 20 degrees + cooler than it was last weekend with a decnet humidity.... i think i can make a 12 out of it.... i hope
Old Mar 19, 2005 | 07:32 PM
  #33
T/A lt1's Avatar
Well the Et street radials are a real good set of tires. I went out last nite with my brand new 325/50/15's. I only got to make 2 n2o passes before they told me to slow down or leave.My car doesn't have a rollbar so the first pass I left easy then sprayed the n2o once the car was about 20-30' out (1.55 60') and ran 10.42@130.5mph with the 150HP jets. Then I pulled up and left on motor then sprayed about 10' out in the 60' and ran a 1.52 60 (driver tire 8inches off the ground) and 10.31@130.8mph which is the quickest I have run on 150HP n2o.
Old Mar 26, 2005 | 12:49 AM
  #34
Drew778/94Z's Avatar
Originally Posted by Deenasty
im heading out to the track in about 2 hours, and I will be trying out my Et Street Radials also. They are 255/50/16, what should I air them at? 12psi? I know that you gain 4psi after the burnout...
I just bought a set, let me know how you did
Old Mar 26, 2005 | 03:16 AM
  #35
Lisa33's Avatar
Nice times, How is the tire clearence, much hammering? What rims do you use? any pics?
Old Apr 5, 2005 | 10:35 PM
  #36
BowTiBrwlr's Avatar
Originally Posted by 4DRSS
Anyone try these out yet? I really like the idea of a GOOD sticky radial tire since I have to drive 30+ miles to any track.
I will be using either the 275/60/15 or 325/50/15 if I can fit them.
How do these compare to ET Streets or ET Drags? I especially value feedback from someone who has used the radials and also the bias ply tires for a true comparison.
I make 476 RWHP and 521 RWTQ do you think I can hook with the radials?
I shattered the Eaton posi in my 12 bolt sat night with a set of well used et street radials...
Old Jun 9, 2005 | 05:05 PM
  #37
blind527's Avatar
What ET Street Radials would you guys recommend with a 17x11 back wheel and 17x9.5 front? Just the ET Street Radials in the back? Which ones?
Old Jun 10, 2005 | 12:15 AM
  #38
blksunshine's Avatar
315/35 on a 17x11
Old Jun 10, 2005 | 12:32 AM
  #39
blind527's Avatar
I dont' believe those are the "specs" M/T gives, they give inches ratios with height and width.
Old Jun 10, 2005 | 08:51 AM
  #40
4DRSS's Avatar
P275/40R17 is the only size ET Street Radial available for 17" wheels.
Old Jun 10, 2005 | 06:08 PM
  #41
reuter's Avatar
they hook great. i try not to launch hard (10 bolt + 6 speed +4.10s) but ripping the 1-2 there is no spin at all.
Old Jun 12, 2005 | 10:07 AM
  #42
nytrus1's Avatar
On my daily driver 94 camaro with nitrous
the best with 27x10.50x15 et streets---1.58 60 ft.
so far with 255/50-16 MT drag radials---1.55 60 ft.
on the motor--- 1.68 60 ft.
I run them @ 12-14 psi and drive them to/from the track (18 miles each way)@ that pressure.
The stiffer sidewall and radial construction makes for a very steady ride with little to no sway unlike et streets.
The bad part with these tires is the treadwear.
I will be buying a second set at the rate I am wearing these out
Louey
Pacific
Oct 1, 2015 12:37 AM
HAWG
Sep 25, 2015 11:41 AM
DelSoto
Sep 19, 2015 05:31 AM
Daluchman1974
Sep 11, 2015 06:12 AM
