Mach 1 runs 13.54
Correct me if I'm wrong, but the Mach I is 305hp, right? I really dont' see that running MM&FF's 13 flat. Motor trend clocked it at 13.8. Sure, maybe their off, but not that much. Looking at the numbers and times I've seen, I'd say the Mach and an LS1 are very, very even. I've never heard of a stock LS1 running better then mid 13's, so unless the mustang weighs alot less, I doubt it could run 13 flat.
The same driver that got a 13 flat out of the mach 1 got a 12.8 out of the ls1, both cars being stock and driven by the mad shifter Evan Smith.
These are definately not the norms for Mach 1s and LS1s though.
Originally posted by xxsaint69x
why are they running so much better then the GTs???
i thought they had the same engine, just differnt intake etc?
Isn't the Mach 1 DOHC 4.6 the same engine that was used on previous Cobras?
the differences are the mach 1s CR is a little higher and it has more aggressive cam(s).if theres anything else i cant remember.did it really run a 13.0 flat?i know one ran a 12.9 with DRs.this a different test run im assuming?
guionM
39
Sep 3, 2002 09:16 PM
CamaroRSguy
Aug 19, 2002 01:52 PM
Z284ever
43
Jun 27, 2002 10:36 AM
guionM
17
Jun 21, 2002 06:43 PM
