M6 with 4:11's on Et Streets
Old Oct 7, 2005 | 11:21 AM
Bow94z's Avatar
WHat should i launch at? i have SLP clutch which will be easier on the rear, im just afriad of breaking teeth with the ET streets, i'll only make a pass or two down the track with ET Streets
Old Oct 7, 2005 | 02:15 PM
Jameslt1TA's Avatar
Re: M6 with 4:11's on Et Streets
Check the thread below by me. This was in my little bro's ls1. we had et streets and were launching at 3500-5000 and it never did spin. These were all clutch drops. My advice would be to sidestep the clutch, you know when you have it around 3 or 4 k and let the clutch only halfway out, then floor it and let the clutch all the way out. This will burn the clutch alittle faster but it will mesh the teeth on the rear together and help to save it.
If i was you i would throw on the et streets and practice some launcing before going to the track.
Remeber 4.10s+ clutch drop, +tick tires=a giant mess of your 10 bolt.
Old Oct 9, 2005 | 08:03 AM
1BADAIR's Avatar
5500rpm here with 4.11's 26/11.50/16 et streets
Old Oct 9, 2005 | 01:22 PM
Bow94z's Avatar
It would be amazing if you could do that on Stock 10bolt
Old Oct 9, 2005 | 02:12 PM
1BADAIR's Avatar
Quasar blue does it. But he has about ten broken 10 bolts laying around.
Old Oct 12, 2005 | 11:13 AM
Bow94z's Avatar
I'll be running ET streets (26/10.5/16), should i run 275/40/17's or 245/50/16 up front. Im trying to research this now, but i dont see too much of what im looking for
Old Oct 12, 2005 | 11:19 AM
Loony's Avatar
Put the 16's up front, it'll be lighter. Plus air up the tires to their max pressure.
Old Oct 12, 2005 | 01:01 PM
Bow94z's Avatar
other opinions?
Louey
Pacific
Oct 1, 2015 12:37 AM
HAWG
Sep 25, 2015 11:41 AM
pepon214tx
Sep 20, 2015 04:48 PM
DelSoto
Sep 19, 2015 05:31 AM
