M/T ET Streets
Old Jan 4, 2003 | 10:59 PM
drptopz's Avatar
M/T ET Streets
Does anyone know if 28 inch ET Streets will fit under a 4th Gen without major cutting?? I've been running 26 X10.5 16's on stock T/A rims, but I'm now running out of gear right before the traps.
I would like to go with a taller tire on my Drag Lite 15 X 10's to get a little more top end, and a little more sidewall, but they don't make 27 inch ET Streets.
I know Hoosier makes a 27 X 10.5 and a 27 X 11.5, but I've had real good success with the ET's and haven't seen many people running the Hoosier Quick Time Pro's.
If it matters, I'm running the Eibach Drag Launch springs / air bag / Spohn torque arm.
Thanks!
Old Jan 5, 2003 | 08:43 AM
Frank95z's Avatar
I'm running the 27X11.5X15 QTP under my 95Z28 with no problems. Ran a 1.51 60ft with them. I'm running the 7.5 convo pro's. Actual tire width is 10in. Frank95z
Old Jan 5, 2003 | 10:45 AM
TedH's Avatar
What offset do you have?
On my 15 x 10 Cragars with a 6 1/2 inch offest, and with a hacksaw to trim the lower wheelwells, mine fit just fine. I trimmed the plastic and just a bit of metal in about 20 minutes to get mine to fit. The tires are 28" x 15" x 12.5".
Old Jan 5, 2003 | 03:43 PM
mongse_1's Avatar
They will fit. I had 275/60-15 Nittos (approx 28x10) on it last year and had to do a little hammer work on the inner fenderwall.
No biggie though.
You may have to cut the urethane flap off from inside the front of the rear bumper too(right by the wheel). It's pretty close and w/ the tire growth on the top end, you'll start rubbing it.
You also may want to think about a 15" rim. More sidewall = good.
Old Jan 5, 2003 | 05:09 PM
drptopz's Avatar
Thanks for the replies guys. I think I'm leaning towards the 27's from Hoosier.
They are going on 15 X 10 Weld Drag Lites.
Dave
Old Jan 5, 2003 | 11:06 PM
mongse_1's Avatar
Crap, just saw the part in the first post about 15x10 Draglites.
The QTPs are good tires and they'll dead hook anywhere. They will wear faster than the M/T tire though.
Old Jan 8, 2003 | 05:53 PM
Chris Ja's Avatar
Eternal Member
Thumbs up
Congrtas guys I hit them last year. This spring I am going for the 11.9. Wish me luck.
Old Jan 8, 2003 | 09:08 PM
ElkyRacer's Avatar
No one has ever mentioned this but....
MT makes a ET Drag, 28x9x15. That shows to be 27.3in tall from what they advertise on a 8in rim. Why not try those? I will.
Kyle
Old Jan 8, 2003 | 09:50 PM
drptopz's Avatar
Kyle
I race in DOT class, they don't like ET Drags... (unfortunatly)
Louey
Pacific
Oct 1, 2015 12:37 AM
HAWG
Sep 25, 2015 11:41 AM
DelSoto
Sep 19, 2015 05:31 AM
Louey
Pacific
Sep 1, 2015 07:19 PM
