M/T ET Streets
M/T ET Streets
Does anyone know if 28 inch ET Streets will fit under a 4th Gen without major cutting?? I've been running 26 X10.5 16's on stock T/A rims, but I'm now running out of gear right before the traps.
I would like to go with a taller tire on my Drag Lite 15 X 10's to get a little more top end, and a little more sidewall, but they don't make 27 inch ET Streets.
I know Hoosier makes a 27 X 10.5 and a 27 X 11.5, but I've had real good success with the ET's and haven't seen many people running the Hoosier Quick Time Pro's.
If it matters, I'm running the Eibach Drag Launch springs / air bag / Spohn torque arm.
Thanks!
Thanks!
What offset do you have?
On my 15 x 10 Cragars with a 6 1/2 inch offest, and with a hacksaw to trim the lower wheelwells, mine fit just fine. I trimmed the plastic and just a bit of metal in about 20 minutes to get mine to fit. The tires are 28" x 15" x 12.5".
They will fit. I had 275/60-15 Nittos (approx 28x10) on it last year and had to do a little hammer work on the inner fenderwall.
No biggie though.
You may have to cut the urethane flap off from inside the front of the rear bumper too(right by the wheel). It's pretty close and w/ the tire growth on the top end, you'll start rubbing it.
You also may want to think about a 15" rim. More sidewall = good.
No biggie though.
