Low 12s With Stock Longblock???
Old Oct 7, 2003 | 08:03 PM
COMNBYU's Avatar
Ok, I picked up some 3.73s and posi from a friend the other day and in about a month I'll have my slipping tranny built with a 3,5k+ stall in. I'm getting a set of hooker LTs from another friend in the next couple of weeks.
Now I've seen a few guys on the board claiming to run low 12s with basically the same set-up I just mentioned, with the exclusion of RRs. How realistic of a goal is this??
My car with no stall/2.73s has been a best of 13.6 and normally runs in the .7s. With built tranny, stall, gears, and LTs, should I be expecting low 12s?? Realistically, I would think mid 12s might be possible. Now these other guys have done some other things such as weight reduct., susp., RRs, etc., but is there really 3-4 tenths to be found there??? (I've already done a tad bit of lb. reduct. jfyi)
Thanks, Jon
Old Oct 7, 2003 | 08:32 PM
RacinLT1's Avatar
yes weight reduction helps. i have run a best of 12.36@109 with a stock longblock and 1.6 rr's.
all depends on how far you wanna take the car apart to run the numbers.
Old Oct 8, 2003 | 04:54 AM
Fastbird93's Avatar
The guy with the Red Trans Am from a couple issues back of GMHTP is a poster on the EFA forum, and he just went 12.03@110 I believe at the MIR shootout. Yes, it's possible, but wieght reduction will definitely be needed.
Old Oct 8, 2003 | 08:44 AM
T/A lt1's Avatar
Yeah that car weighs 3150lbs w/o driver so I would say major weight reduction and alot of tuning both engine and suspension. It takes 1.5-low 1.6's 60's to go low 12's with a stock engine and that is no easy task. It also takes some decent air. I think a more realsitic goal would be 12.90's until you get the car dialed in. JMO. Later Clint
Old Oct 8, 2003 | 10:51 AM
Shon Herron's Avatar
Anything is possible!!
Get the weight out, it helps ET and is easier on parts. The car needs to be in the 3300#s or less with driver. I would really choose the right TC for the application. Just getting a large stall is not the best idea. I think a Yank ST3500 would be good or a Vig 2800. You want to use all the Low end TQ the LT1 produces and not get too ahead of it. Sticky tires is a must as well with alot of gear!! 3.73s will not be enough in my opinion...4.10s would be a better choice.
good luck!
Old Oct 8, 2003 | 02:52 PM
TedH's Avatar
I would be hoping for high 12's. You need to remove a LOT of weight to get down to where you can run low 12's with a stock car.
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
Mar 13, 2016 03:39 PM
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
