Looking for a good drag slick.
Old May 17, 2006 | 05:02 PM
slow95camaroz28's Avatar
Im looking for a slick that will fit my stock 95 rims. If you could post links to them i would appreciate it. Also what brand is good? I have been looking at mickey thompson and hoosier, but cant find anything that will fit my stock rim. Thanks
Old May 17, 2006 | 07:21 PM
Stephen 87 IROC's Avatar
Re: Looking for a good drag slick.
www.mickeythompsontires.com
www.hoosiertire.com
www.racegoodyear.com
I've tried them all. I like the Hoosier the best but they wore out quickly. I currently have MT on my car just because we have a local supplier that has stock. Everything other brand needs to be ordered in or it's an out of town pickup.
Old May 17, 2006 | 11:38 PM
Well i still cant find anything that can fit my stock rim can someone help me out?
Old May 17, 2006 | 11:47 PM
lt11997's Avatar
http://store.summitracing.com/partde...5&autoview=sku
Old May 18, 2006 | 01:34 AM
thanks thoes look nice, any other suggestions?
Old May 18, 2006 | 02:51 AM
Soccerbum21's Avatar
Mickey Thompson ET Streets. i have 26x10.5x16 on my stock 95 wheels...the ones in the above post are the street radials
i cut 1.5 60's with them and they have hardly shown any wear for the number of passes i have on them.
i think they cost me about 365 shipped from jegs.
this isnt a tire i would recommend running on the street, even though they are "DOT approved" they are basically a full on slick with grooves cut in them
Old May 19, 2006 | 01:35 AM
lt11997's Avatar
I have ET Streets also, Ihave only made 6 passes on them, What do you have the tire pressure set at for the track. I also only use these on the track.
Old May 20, 2006 | 10:13 PM
89385formula's Avatar
Hoosier QTP's work GREAT. Of the tires I have tried the only thing in the same realm of comparison would be MT ET Drags, which aren't DOT approved like the QTP's are. Here's the summit link for some that would work good for stock wheels.
http://store.summitracing.com/partde...part=HOO-17430
Old May 24, 2006 | 01:52 PM
i'm running 14-14.5 psi in them. i have heard a lot of people getting uncomfortable with the car leanin' and rockin' at the end of the track, esp. under braking with anything lower than 18.
but when i first got them, i set them at 18 and went down til i hooked the way i wanted. i am getting 1.5 60's with a stock 2.73 rear end and stock transmission/torque converter. so i say they're hooking well now.
Old May 28, 2006 | 08:52 AM
The Engineer's Avatar
I just received the latest issue of National Dragster (May 26). Mickey Thompson has an add (page 58) for their new "Pro Drag Radial." Which is a true drag slick, but in a new radial design for stockers and super stockers with autos. Does anyone have these new slicks, and if so, how do they perform?
I'm currently using ET Streets and run them at 13.0 to 14.5 psi without any stability or control problems at the line.
http://www.cardomain.com/ride/2189634
RUENUF
Mar 13, 2016 03:39 PM
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Fbodfather
25
Jun 21, 2002 04:12 PM
