Lite weight front brakes?
Old Jan 16, 2005 | 09:37 PM
rje's Avatar
rje
I was wondering if anybody knows if anyone makes lite weight rotor and calipers for a 94 Z to use in drag racing. I really don't want giant rotors and six piston calipers, because I run a 15in wheel. What I would like is a stock sized slotted or drilled rotor and a nice aluminuin two piston caliper. This would decrease a little weight off the nose of the car and should allow the wheel to turn more freely vs the stock caliper which wants to drag on the rotor slightly. Any info would be great. Thanks.
Randy
Old Jan 16, 2005 | 10:13 PM
sseeya's Avatar
Re: Lite weight front brakes?
Mark Williams, Strange, and Aerospace all make lightweight brake kits for the 4th Generation F-body. Jay at Billingsley Racing sells both Strange and Aerospace. You can buy the Mark Williams directly from them.
Old Jan 17, 2005 | 10:47 AM
rje's Avatar
rje
Thanks for the info! I've been looking for a kit like this for a while. It should knock 40-50 lbs off the nose of the car which would be great.
Randy
Old Jan 18, 2005 | 11:44 AM
N20Dave's Avatar
FWIW, I have the aerospace ones from Billingsley and they work pretty good. Light too.
Old Jan 18, 2005 | 12:44 PM
MustangEater82's Avatar
pfft... a hardcore racer woudl just !front brakes...
don't half *** it
Old Jan 18, 2005 | 12:48 PM
rje's Avatar
rje
I just ordered the aerospace kit and the hoses. I should have everything by the first of next week.
Randy
Old Jan 18, 2005 | 02:18 PM
N20Dave's Avatar
don't half *** it
Rock on bro. That's what they make chutes for
Old Jan 18, 2005 | 02:19 PM
N20Dave's Avatar
BTW, I weighed my Baer setup and the Aerospace setup and I ended up with a net savings of 41 lbs.
Old Jan 18, 2005 | 02:31 PM
wow that is a pretty big difference...
Old Jan 18, 2005 | 02:40 PM
sseeya's Avatar
Dave,
Was the Baer setup lighter than the stock setup or heavier? Just curious as to what kind of weight saving you would see over stock.
Old Jan 18, 2005 | 04:06 PM
N20Dave's Avatar
I never weighed the stock stuff but the Baer setup looks to be heavier than stock by a little. I'd have to think that your get at least 30 lbs difference over stock.
Old Jan 21, 2005 | 07:17 AM
Nostang 96z's Avatar
Are these brakes streetable? I am running stockers on mine with a manual master cylinder and would like to upgrade if these are able to be driven on the streets.
Magenta_Hearts
Mar 29, 2017 08:54 PM
Brake_L8
Jan 20, 2015 09:44 AM
Hurin
Dec 13, 2014 07:38 PM
Jul 4, 2005 05:00 PM
