Lite weight front brakes?
I was wondering if anybody knows if anyone makes lite weight rotor and calipers for a 94 Z to use in drag racing. I really don't want giant rotors and six piston calipers, because I run a 15in wheel. What I would like is a stock sized slotted or drilled rotor and a nice aluminuin two piston caliper. This would decrease a little weight off the nose of the car and should allow the wheel to turn more freely vs the stock caliper which wants to drag on the rotor slightly. Any info would be great. Thanks.
Randy
Randy
Re: Lite weight front brakes?
Mark Williams, Strange, and Aerospace all make lightweight brake kits for the 4th Generation F-body. Jay at Billingsley Racing sells both Strange and Aerospace. You can buy the Mark Williams directly from them.
Originally Posted by N20Dave
BTW, I weighed my Baer setup and the Aerospace setup and I ended up with a net savings of 41 lbs.
Was the Baer setup lighter than the stock setup or heavier? Just curious as to what kind of weight saving you would see over stock.
Magenta_Hearts
Mar 29, 2017 08:54 PM
Brake_L8
Jan 20, 2015 09:44 AM
Hurin
Dec 13, 2014 07:38 PM
Jul 4, 2005 05:00 PM
